But does it react to Chroma Weight or not regardless of how it looks, is there a visible change? That is what matters.
aboulfad
Post by aboulfad »
Ah… yes it does, meaning ‘original’ doesn’t look as ‘no-trim-chroma-weight’ and I see a change. I thought color aspects (i.e. chroma) were important. When Oppo was in player led, both original & sub-sequent shot were the same.
aboulfad wrote:
Fri Jan 12, 2024 5:51 pm
Then it is normal and this is why one should never use the Cinema Home mode unless maybe if your TV is in a bright room.
aboulfad
Post by aboulfad »
I actually dont use ‘Cinema Home’, rather ‘Cinema’. I was trying picmode ‘DV Game’ & it gave same results as ‘Cinema Home’ for chroma weight, an avsforum user recommended that mode for DV movie viewing over ‘Cinema’.
yeah AFAIK only ''cinema'' is accurate on LG TVs.
Speaking of Chroma Weight, the latest amazon prime original movie does use it quite a lot. And IMO there's a much more concerning bug with TV-LED where any positive lift for trims offset doesn't work.
JCLG8
Post by JCLG8 »
So on DoVi_scripts it said unsupported codec with truehd, but the truehd and ac3 files were seperate. I think they need to be combined for it to be supported?
you have to provide more info if you want me to help you.
1- input media info
2- log of the script with ''echo on'' preferably
JCLG8
Post by JCLG8 »
I assume I just copy the text from the command line for the log, but what is echo and how do I turn it on?
JCLG8 wrote:
Fri Jan 12, 2024 6:49 pm
open the bat file with notepad and change the 2nd line
@echo on
valington
Post by valington »
RESET_9999 wrote:
Fri Jan 12, 2024 1:41 pm
azreil24 wrote:
Fri Jan 12, 2024 1:34 pm
I tried playing with some more converting from MKV into MP4 and TS and it seems these two scripts have issues with file drop, they do not pick up the file path, I had to enter it manually for both. MKV script seems to work fine. Also, the MP4 converting flow processed the audio and subs two times, although I only had one of each.
No issue on my end and there is no difference between the mp4/ts or mkv version, its all the same script. I know drag and drop doesn't work on Windows 11 if you launch the script in admin rights.
I wouldn't use the auto ocr sup to srt though.
YES script doing audio and subtitles two times in mp4 7 profile mode and something wrong with dolby vision layers they are wrong plese fix it
please try the version posted yersterday here
aboulfad
Post by aboulfad »
RESET_9999 wrote:
Fri Jan 12, 2024 6:05 pm
...Speaking of Chroma Weight, the latest amazon prime original movie does use it quite a lot. And IMO there's a much more concerning bug with TV-LED where any positive lift for trims offset doesn't work.
Oh you mean the Prime movie "Role Play", anything one should watch for related to this "bug" ? i.e. is it visible to the naked eye in some scene ?
aboulfad wrote:
Fri Jan 12, 2024 7:37 pm
All the HDMI devices I tested will ignore any positive lift for Trim offset so it will reflect in a darker image.
test file if you want to see it with your own eyes: https://drive.google.com/file/d/1JrU6JX ... drive_link
This is a much bigger issue than the LLDV CW bug because L2 trim offset is calculated automatically by the Dolby algo (then the colorist can edit it) so unlike Chroma Weight which must come from the colorist, trim offset is used a lot more often in real content and only the TV internal player support it. (ironically, all the devices support it just fine in LLDV)
aboulfad
Post by aboulfad »
RESET_9999 wrote:
Fri Jan 12, 2024 7:43 pm
I assume I need to check around 2 minutes in the video for the L1 + 'trim chroma weight' ? if so, using Oppo/Cinema on my TV, I couldn't spot anything different. For other segments, I did see a change.
aboulfad wrote:
Fri Jan 12, 2024 8:03 pm
I'm talking about L2 trim offset, not CW which doesn't have an effect in that frame.
