#9486
Post
by aboulfad » Fri Jan 12, 2024 5:21 pm
^^^ Sorry, not sure how to explain & maybe I am confused, so I’ll be verbose.
The LLDV test pattern has an ‘original’ shot of the eagle that it’s thing on top of its beak supposed to look nice & yellow that we all know.
The 2nd shot right after, ‘no chroma weight’ looks bland and not as yellow (green?). If I set Oppo to player led, then the original shot (which I assume has chroma weight), looks identical to the ‘no chroma weight’.
Now, pausing the DV test pattern on ‘original’, if use the mode ‘cinema user’ that I applied a DV calibration profile & changes to 2/20 points, it looks as it’s meant to be. If I use default Cinema Home mode, then that looks very similar to the test pattern ‘no chroma weight’ shot.
Idk if it’s cinema and/or the DV cal file that makes a difference, I can try on the TV usb input once I figure out what this 2017 E7 accepts as file formats & dovi profiles.
