ragico
#9466 Post by ragico » Thu Jan 11, 2024 11:52 pm
In your opinion which gives the best quality nearest the creator's intent on X800m2, via Serviio in ts containers, between STDL and DTDL?
azreil24
#9467 Post by azreil24 » Thu Jan 11, 2024 11:57 pm
RESET_9999 wrote:
Thu Jan 11, 2024 10:55 pm
Kodi audio setting is set to ''best match'' ??
Yes, tried with the other options as well, same thing. Curious about the bit-rate of the movies you have watched and played fine, as Hugo for example reaches even 130Mbps peaks. Maybe this is what causes Kodi to stumble, at least this LG version.
#9468 Post by RESET_9999 » Fri Jan 12, 2024 12:47 am
they are both the same quality but as you know, some ST-DL won't work so it's more practical to use DT-DL.
The highest bitrate movie I watched so far on Kodi:
JCLG8
#9469 Post by JCLG8 » Fri Jan 12, 2024 1:43 am
Is there any difference between TS and M2TS?
#9470 Post by RESET_9999 » Fri Jan 12, 2024 2:32 am
not in quality or support
#9471 Post by RESET_9999 » Fri Jan 12, 2024 12:05 pm
I just remember something. You cant have both plex and kodi launched at the same time, it causes stuttering. (at least when using the composite addon). Maybe you had the plex app running ??
azreil24
#9472 Post by azreil24 » Fri Jan 12, 2024 1:34 pm
Sadly no, I always close one or the other or any other app.
I tried playing with some more converting from MKV into MP4 and TS and it seems these two scripts have issues with file drop, they do not pick up the file path, I had to enter it manually for both. MKV script seems to work fine. Also, the MP4 converting flow processed the audio and subs two times, although I only had one of each.
#9473 Post by RESET_9999 » Fri Jan 12, 2024 1:41 pm
No issue on my end and there is no difference between the mp4/ts or mkv version, its all the same script. I know drag and drop doesn't work on Windows 11 if you launch the script in admin rights.
I wouldn't use the auto ocr sup to srt though.
azreil24
#9474 Post by azreil24 » Fri Jan 12, 2024 1:49 pm
Oh, so no admin rights, got it. I do that by habit sometimes :D Yeah, the OCR is not perfect, but better than nothing and having to mux the files again only to remove the PGS tracks. Can I change the scripts to not even process the PGS at all, to discard them?
#9475 Post by RESET_9999 » Fri Jan 12, 2024 1:53 pm
Not in the version on github but get the unreleased version I posted yesterday here: viewtopic.php?p=146748#p146748
This version has sup to srt disabled by default (line 40).
azreil24
#9476 Post by azreil24 » Fri Jan 12, 2024 1:54 pm
Yes, but that is the MKV script, was referring to MP4/TS ones :)
#9477 Post by RESET_9999 » Fri Jan 12, 2024 1:57 pm
As explained on github, the bat filename determines the muxing behavior. so just rename it to TS or MP4.
sorry if its not clear, my English is not great.
azreil24
#9478 Post by azreil24 » Fri Jan 12, 2024 2:17 pm
My bad, so sorry, I missed that it seems :D
azreil24
#9479 Post by azreil24 » Fri Jan 12, 2024 2:29 pm
Just sent over a little something to thank you for your work. Many thanks! :)
#9480 Post by RESET_9999 » Fri Jan 12, 2024 2:33 pm
thanks man, I appreciate it :D
I gave you access to my RPU collections.
