In your opinion which gives the best quality nearest the creator's intent on X800m2, via Serviio in ts containers, between STDL and DTDL?
Yes, tried with the other options as well, same thing. Curious about the bit-rate of the movies you have watched and played fine, as Hugo for example reaches even 130Mbps peaks. Maybe this is what causes Kodi to stumble, at least this LG version.
they are both the same quality but as you know, some ST-DL won't work so it's more practical to use DT-DL.
The highest bitrate movie I watched so far on Kodi:
Is there any difference between TS and M2TS?
not in quality or support
I just remember something. You cant have both plex and kodi launched at the same time, it causes stuttering. (at least when using the composite addon). Maybe you had the plex app running ??
Sadly no, I always close one or the other or any other app.RESET_9999 wrote: ↑Fri Jan 12, 2024 12:05 pmI just remember something. You cant have both plex and kodi launched at the same time, it causes stuttering. (at least when using the composite addon). Maybe you had the plex app running ??
I tried playing with some more converting from MKV into MP4 and TS and it seems these two scripts have issues with file drop, they do not pick up the file path, I had to enter it manually for both. MKV script seems to work fine. Also, the MP4 converting flow processed the audio and subs two times, although I only had one of each.
No issue on my end and there is no difference between the mp4/ts or mkv version, its all the same script. I know drag and drop doesn't work on Windows 11 if you launch the script in admin rights.azreil24 wrote: ↑Fri Jan 12, 2024 1:34 pmI tried playing with some more converting from MKV into MP4 and TS and it seems these two scripts have issues with file drop, they do not pick up the file path, I had to enter it manually for both. MKV script seems to work fine. Also, the MP4 converting flow processed the audio and subs two times, although I only had one of each.
I wouldn't use the auto ocr sup to srt though.
Oh, so no admin rights, got it. I do that by habit sometimesRESET_9999 wrote: ↑Fri Jan 12, 2024 1:41 pmNo issue on my end and there is no difference between the mp4/ts or mkv version, its all the same script. I know drag and drop doesn't work on Windows 11 if you launch the script in admin rights.azreil24 wrote: ↑Fri Jan 12, 2024 1:34 pmI tried playing with some more converting from MKV into MP4 and TS and it seems these two scripts have issues with file drop, they do not pick up the file path, I had to enter it manually for both. MKV script seems to work fine. Also, the MP4 converting flow processed the audio and subs two times, although I only had one of each.
Not in the version on github but get the unreleased version I posted yesterday here: viewtopic.php?p=146748#p146748
This version has sup to srt disabled by default (line 40).
Yes, but that is the MKV script, was referring to MP4/TS ones
As explained on github, the bat filename determines the muxing behavior. so just rename it to TS or MP4.
sorry if its not clear, my English is not great.
My bad, so sorry, I missed that it seems
Just sent over a little something to thank you for your work. Many thanks!
thanks man, I appreciate it
I gave you access to my RPU collections.
