JCLG8
Post by JCLG8 » Thu Jan 11, 2024 9:07 pm
RESET_9999 wrote: Thu Jan 11, 2024 8:24 pm
JCLG8 wrote: Thu Jan 11, 2024 8:09 pm How can I convert a single track dual layer P7 mkv to dual track dual layer m2ts? And will the quality be the same after the conversion?
In dovi_scripts TS version, workflow 4-3.
No quality loss.
Got it thanks. I tried with dovi scripts and because it had a truehd track it said it was unsupported.
Post by RESET_9999 » Thu Jan 11, 2024 9:10 pm
JCLG8 wrote: Thu Jan 11, 2024 9:07 pm Got it thanks. I tried with dovi scripts and because it had a truehd track it said it was unsupported.
THD is definitely supported, I use 4-3 very often.
I just did a few hours ago: Sweeney Todd The Demon Barber of Fleet Street 2007 P7 mkv to DTDL TS.
JCLG8
Post by JCLG8 » Thu Jan 11, 2024 9:23 pm
RESET_9999 wrote: Thu Jan 11, 2024 9:10 pm
I am gonna test it again and get back to you. Also maybe it's just like this for me, but I have seen that unless I use the bat files with administrator rights it doesn't work right. Like it doesn't detect the files I think.
azreil24
Post by azreil24 » Thu Jan 11, 2024 10:29 pm
RESET_9999 wrote: Thu Jan 11, 2024 8:56 pm
azreil24 wrote: Thu Jan 11, 2024 8:38 pm The 8-2 flow created a 7.1 track with 1024kbps bit-rate, which seems to play fine in the LG TV's Kodi. Also, not sure if this Kodi is so smart, as otherwise I hate it with a passion, but seems the sound is in sync playing through it. Either it's that smart or it just happens that its usual delay is around 1 second, which is the delay required in my test case. I have a feeling it's the later. Through Zidoo I have the delay also.
yes, 7.1 encoding with my the script is limited to 1024kbps.
It's the 5.1 encoding that can go up to 1536 and it stutter in Kodi so that's why you need the unreleased version of the script I just posted for those.
So, LG TV's Kodi still sucks. I corrected the delay and now I got the correct sync when played on PC or Zidoo. When played through the Kodi Plex add-on, there is a slight delay on the video, I can notice a 2-300ms of delay. Playing the same file directly into Kodi, I get a delay in sound. It's annoying as hell getting DV MKVs to play properly on the LG...
Post by RESET_9999 » Thu Jan 11, 2024 10:31 pm
azreil24 wrote: Thu Jan 11, 2024 10:29 pm So, LG TV's Kodi still sucks. I corrected the delay and now I got the correct sync when played on PC or Zidoo. When played through the Kodi Plex add-on, there is a slight delay on the video, I can notice a 2-300ms of delay. Playing the same file directly into Kodi, I get a delay in sound. It's annoying as hell getting DV MKVs to play properly on the LG...
I have no such issue and I watched like 5 movies and two seasons of a TV show.
C2 to Denon AVR
azreil24
Post by azreil24 » Thu Jan 11, 2024 10:35 pm
RESET_9999 wrote: Thu Jan 11, 2024 10:31 pm
C2 to Denon AVR
Are you playing them from USB HDD connected to the LG or through network server?
Post by RESET_9999 » Thu Jan 11, 2024 10:40 pm
azreil24 wrote: Thu Jan 11, 2024 10:35 pm Are you playing them from USB HDD connected to the LG or through network server?
Via my network (5ghz wifi and router in the same room as my TV) with plex composite addon to access my library. TV audio is set to ''passthrough'' with ARC.
I noticed that if you change subtitles tracks during playback it can cause sync issues. In that case, I just stop the movie and resume it.
Using plex ''skip intro'' function also work fine and doesn't cause issues.
azreil24
Post by azreil24 » Thu Jan 11, 2024 10:51 pm
RESET_9999 wrote: Thu Jan 11, 2024 10:40 pm
My network is wired, 1Gbps. Everything plays fine on any other device. I got a USB LAN connection to the C2, hitting almost 400Mbps download and upload. So plenty of speed. Playing the same file through the native Plex app, so without DV, plays flawlessly.
Changing subtitles only affects Kodi playback, also, skipping on Kodi causes the movie to start stuttering every 5 seconds. Playing through Plex Kodi add-on, subs and skipping do not affect playback. It's very weird. I hate this Kodi with a passion, don't understand how people are happy with it as everything is counter-intuitive. I accidentally removed the Movies tile from the Home page, God knows how I can get it back. Removing sources from the library doesn't also remove the titles that were in that removed source and many other issues.
Doing an MP4 conversion now using your scripts. Didn't knew it also does PGS conversion, that's cool. Curious if with MP4 I face the same issues.
Post by RESET_9999 » Thu Jan 11, 2024 10:55 pm
Kodi audio setting is set to ''best match'' ??
ragico
Post by ragico » Thu Jan 11, 2024 11:52 pm
In your opinion which gives the best quality nearest the creator's intent on X800m2, via Serviio in ts containers, between STDL and DTDL?
azreil24
Post by azreil24 » Thu Jan 11, 2024 11:57 pm
RESET_9999 wrote: Thu Jan 11, 2024 10:55 pm Kodi audio setting is set to ''best match'' ??
Yes, tried with the other options as well, same thing. Curious about the bit-rate of the movies you have watched and played fine, as Hugo for example reaches even 130Mbps peaks. Maybe this is what causes Kodi to stumble, at least this LG version.
Post by RESET_9999 » Fri Jan 12, 2024 12:47 am
ragico wrote: Thu Jan 11, 2024 11:52 pm RESET_9999
they are both the same quality but as you know, some ST-DL won't work so it's more practical to use DT-DL.
azreil24 wrote: Thu Jan 11, 2024 11:57 pm Yes, tried with the other options as well, same thing. Curious about the bit-rate of the movies you have watched and played fine, as Hugo for example reaches even 130Mbps peaks. Maybe this is what causes Kodi to stumble, at least this LG version.
The highest bitrate movie I watched so far on Kodi:
JCLG8
Post by JCLG8 » Fri Jan 12, 2024 1:43 am
Is there any difference between TS and M2TS?
Post by RESET_9999 » Fri Jan 12, 2024 2:32 am
not in quality or support
Post by RESET_9999 » Fri Jan 12, 2024 12:05 pm
I just remember something. You cant have both plex and kodi launched at the same time, it causes stuttering. (at least when using the composite addon). Maybe you had the plex app running ??
