JCLG8
#9421 Post by JCLG8 » Thu Jan 11, 2024 12:16 am
RESET_9999 wrote: Wed Jan 10, 2024 11:43 pm Yes, it's either the ATV: I'm pretty sure cmv4.0 is broken and all my TV-LED measurements from the ATV were noticeably darker than the Shield and X800m2
or the Shield: Red push, lots of dropped frames, Resume is buggy, the UI is not great and also buggy.
On my end, I switched to Kodi C2 internal app with MKV and I use my X800m2 only for FEL or when the lossless audio is important (action movies).
Aside from chroma weight what is wrong with LLDV? Does it have all those issues ragico stated? Or are those issues just with those other players like the shield, the firestick and those others he mentioned?
ragico
#9422 Post by ragico » Thu Jan 11, 2024 12:42 am
Of course is a matter of choice. I cannot stand the shield problems and have sold it months ago. I can live with the P8 cm2.9 in Infuse and hope that Apple will also add support for P8 cm4.0. As for lossless audio, Apple converts everything in PCM but the quality is excellent to my ears. So, as you, I use the X800m2 only for Fel and for Dolby Atmos when needed, my Sonos soundbar does not support Dts HD/Dts X
speeddemon
#9423 Post by speeddemon » Thu Jan 11, 2024 12:44 am
JCLG8 wrote: Wed Jan 10, 2024 7:11 pm Good to know. I thought I wasted my money for a second because apperantly I cannot do TV-LED but with LLDV for real content there is no difference I guess.
JCLG8 wrote: Thu Jan 11, 2024 12:16 am Aside from chroma weight what is wrong with LLDV? Does it have all those issues ragico stated? Or are those issues just with those other players like the shield, the firestick and those others he mentioned?
The difference between Player-led and TV-led Dolby Vision is significant on a calibrated/capable display:
  1. For Player-led (or Fake TV-led in this conversation), the player only knows a small amount about the display through the HDMI EDID handshake, primarily MaxCLL. This is not enough information to fully dynamically tone map. This is better than static metadata HDR10 but leaves most dynamic tone mapping capabilities on the table since a display's characteristics are more complicated than just its max luminance and/or max APL.
  2. For TV-led, The display's 3D LUT, chromaticity+Luminance at all APL levels, near-black performance, and additional display characteristics are all considered while mapping.
#9424 Post by RESET_9999 » Thu Jan 11, 2024 12:49 am
ragico wrote: Thu Jan 11, 2024 12:42 am hope that Apple will also add support for P8 cm4.0.
ATV already supports cmv4.0 P8 and as I said, it doesn't work well. In TV-LED it is not as bad as this but I still can see it: https://slow.pics/c/VGBhNeQU
it's fine as long as your edid is under 1000nits.
JCLG8
#9425 Post by JCLG8 » Thu Jan 11, 2024 12:54 am
RESET_9999 wrote: Thu Jan 11, 2024 12:49 am
Cool thanks. What about what speeddemon said?
ragico
#9426 Post by ragico » Thu Jan 11, 2024 1:08 am
Yes I know that ATV already supports cm4.0 (I did a trial a couple months ago with a mp4 played by Apple native player and it worked albeit with audio problem). Sorry for my error in the previous post, I intend to say that hope that Infuse adds support for P8 cm4.0.
Will see what happens in next months.
#9427 Post by RESET_9999 » Thu Jan 11, 2024 1:19 am
JCLG8 wrote: Thu Jan 11, 2024 12:54 am Cool thanks. What about what speeddemon said?
what about it?
TV-LED is preferred but that doesn't make LLDV inaccurate with the right player/setup. Dynamic is better than static...
ragico wrote: Thu Jan 11, 2024 1:08 am I intend to say that hope that Infuse adds support for P8 cm4.0.
I doubt cmv4.0 will be any different than what it is right now with the native player.
JCLG8
#9428 Post by JCLG8 » Thu Jan 11, 2024 1:28 am
RESET_9999 wrote: Thu Jan 11, 2024 1:19 am
what about it?
Yeah thanks, I am just asking like, does it really leave most dynamic tone mappings out? And even though TV-LED is better is there a big difference?
#9429 Post by RESET_9999 » Thu Jan 11, 2024 1:34 am
I dont know, I didn't compare TV-LED to LLDV much.
My main setup(C2) is far from my lldv testing setup(cheap TV) so I can't force LLDV on my C2 (x800m2) without removing the Vertex(can force lldv) from my testing setup.
JCLG8
#9430 Post by JCLG8 » Thu Jan 11, 2024 1:36 am
I see, I just hope I am not missing out too much by not having TV-LED.
speeddemon
#9431 Post by speeddemon » Thu Jan 11, 2024 2:11 am
JCLG8 wrote: Thu Jan 11, 2024 1:36 am I see, I just hope I am not missing out too much by not having TV-LED.
If you have a choice, then go TV-led. If you don't, then just use LLDV. The difference is typically substantial in my testing.
How important it is to you should depend on a wide spectrum, ranging from something like a professional colorist to being the type of person who takes a TV out of the box and leaves it in vivid mode. Only you know where you fall on that spectrum.
JCLG8
#9432 Post by JCLG8 » Thu Jan 11, 2024 2:13 am
speeddemon wrote: Thu Jan 11, 2024 2:11 am
Is there some way to force the X700 into TV-LED?
susanstone2022
#9433 Post by susanstone2022 » Thu Jan 11, 2024 2:34 am
speeddemon wrote: Thu Jan 11, 2024 12:44 am
I don't think player-led is bad as long as it is done right. For example, it is said Panasonic player has the best tone mapping or picture quality.
aboulfad
#9434 Post by aboulfad » Thu Jan 11, 2024 2:37 am
RESET_9999 wrote: Thu Jan 11, 2024 12:49 am ATV already supports cmv4.0 P8 and as I said, it doesn't work well. In TV-LED it is not as bad as this but I still can see it: https://slow.pics/c/VGBhNeQU
What is it you see ? I converted "color bar RGB 0-10 000nits P8 DoVi cmv4.0 L1 only.ts" to mp4, added to my "Home movies" on my MBP & then viewed on ATV4K3 in DV using native player, see comparison with Oppo. ATV has artifacts in one red square but the gradient is there for all colours, camera photo was just a quick shot.
#9435 Post by RESET_9999 » Thu Jan 11, 2024 2:48 am
aboulfad wrote: Thu Jan 11, 2024 2:37 am What is it you see ? I converted "color bar RGB 0-10 000nits P8 DoVi cmv4.0 L1 only.ts" to mp4, added to my "Home movies" on my MBP & then viewed on ATV4K3 in DV using native player, see comparison with Oppo. ATV has artifacts in one red square but the gradient is there for all colours, camera photo was just a quick shot.
yep, that's what I'm seeing too. Those artifacts are not on the Shield TV-LED nor on the C2 internal player.
JCLG8 wrote: Thu Jan 11, 2024 2:13 am Is there some way to force the X700 into TV-LED?
TV-LED can only work if the TV support it.
