susanstone2022
#9436 Post by susanstone2022 » Thu Jan 11, 2024 2:34 am
speeddemon wrote:
Thu Jan 11, 2024 12:44 am
JCLG8 wrote:
Wed Jan 10, 2024 7:11 pm
Good to know. I thought I wasted my money for a second because apperantly I cannot do TV-LED but with LLDV for real content there is no difference I guess.
JCLG8 wrote:
Thu Jan 11, 2024 12:16 am
Aside from chroma weight what is wrong with LLDV? Does it have all those issues ragico stated? Or are those issues just with those other players like the shield, the firestick and those others he mentioned?
The difference between Player-led and TV-led Dolby Vision is significant on a calibrated/capable display:
  1. For Player-led (or Fake TV-led in this conversation), the player only knows a small amount about the display through the HDMI EDID handshake, primarily MaxCLL. This is not enough information to fully dynamically tone map. This is better than static metadata HDR10 but leaves most dynamic tone mapping capabilities on the table since a display's characteristics are more complicated than just its max luminance and/or max APL.
  2. For TV-led, The display's 3D LUT, chromaticity+Luminance at all APL levels, near-black performance, and additional display characteristics are all considered while mapping.
I don't think player-led is bad as long as it is done right. For example, it is said Panasonic player has the best tone mapping or picture quality.
aboulfad
#9437 Post by aboulfad » Thu Jan 11, 2024 2:37 am
RESET_9999 wrote:
Thu Jan 11, 2024 12:49 am
ATV already supports cmv4.0 P8 and as I said, it doesn't work well. In TV-LED it is not as bad as this but I still can see it: https://slow.pics/c/VGBhNeQU
What is it you see ? I converted "color bar RGB 0-10 000nits P8 DoVi cmv4.0 L1 only.ts" to mp4, added to my "Home movies" on my MBP & then viewed on ATV4K3 in DV using native player, see comparison with Oppo. ATV has artifacts in one red square but the gradient is there for all colours, camera photo was just a quick shot.
#9438 Post by RESET_9999 » Thu Jan 11, 2024 2:48 am
yep, that's what I'm seeing too. Those artifacts are not on the Shield TV-LED nor on the C2 internal player.
JCLG8 wrote:
Thu Jan 11, 2024 2:13 am
Is there some way to force the X700 into TV-LED?
TV-LED can only work if the TV support it.
JCLG8
#9439 Post by JCLG8 » Thu Jan 11, 2024 2:51 am
Right, is it really leaving most dynamic tone mapping capabilities out in LLDV like he said?
#9440 Post by RESET_9999 » Thu Jan 11, 2024 2:58 am
i dont know
JCLG8
#9441 Post by JCLG8 » Thu Jan 11, 2024 3:01 am
Anyway sorry for asking so many questions. I assume at least even LLDV is better than the TV’s dynamic tone mapping with hdr10?
speeddemon
#9442 Post by speeddemon » Thu Jan 11, 2024 6:11 pm
That's great if LLDV meets your needs.
Still, my experience from testing the following players indicates a significant difference between Player-led and Standard-led when displayed on a calibrated/accurate LG or Sony OLED (A95K is the only Sony with accurate DV): Zidoo/Dune Realtek RTD1619DR, Dune/Homatics Amlogic S905X4-K, 2021/2023 Fire TV Stick 4K Max, CCwGTV4K, 2019 Shield TV Pro, 2018-2023 LG WebOS, 2021/2022 Apple TV 4K, and Oppo UDP-203.
susanstone2022
#9443 Post by susanstone2022 » Thu Jan 11, 2024 7:10 pm
Based on posts in this thread:
The only true TV-led devices are Shield and Apple TV.
All other streaming devices are fake TV-led.
All UHD players - Oppo and Sony - pre-process RPU in some unknown way. They do keep some parts of RPU for TV to processes.
TV internal players are not very clear.
azreil24
#9444 Post by azreil24 » Thu Jan 11, 2024 7:40 pm
Hey Reset. What can I do to have the EAC3 re-encode of the DTS tracks automatically align with the movie as the original DTS track? I used the 8-2 flow for MKV and muxed the EC3 track using MKVToolNix and the EAC3 audio track is out of sync.
#9445 Post by RESET_9999 » Thu Jan 11, 2024 7:53 pm
If it's a 7.1 THD or DTS track, you have to set the delay manually in mkvtoolnix because the EAE encoder output raw ec3 tracks. You can use mediainfo to get the delay.
If it is a 5.1 lossless audio track, the file is encoded to an mkv and the delay is preserved so I guess your input is 7.1???
If opt to encode EC3 with all the other workflows, the delay is set automatically when it mux.
I'll add the delay in the filename for 7.1 EC3 in the next version.
If it's for the LG TVs kodi, the 5.1 1536kbps tracks will not work. You can use this non-offical not released dovi script version ( a lot changed in this version though, DDP encoding is now 8-1-1):
https://drive.google.com/file/d/128gq8a ... sp=sharing
- MP4 version: External audio(ec3/ac3/aac only) or sub(srt only) with the same filename/path will now get muxed. Will use the the script language local settings.
- MP4 version: Added mp4 muxing in all the batch workflows (1-2) (2-1-5) (2-1-2) (3-1) (2-1-4)
- Added (Line 63) an option to fix appleTV bitstream framerate in all the workflows. Can also be triggered with ''FIXAPPLE'' in the input filename. (Default=NO Expect 23.976 input.)
- Added support for HDR10plus scene cut export in (2-4) (2-5). If input has DV and HDR10plus, DV is selected. HDR10plus can be forced by adding ''FORCEHDR10PLUS'' in the filename
- Added an option to enable/disable SUP to SRT ocr conversion (line 40) (default = NO) if export.subs=NO this option has no effect for the TS and MKV version. Keep in mind that auto ocr is not perfect.
- Added (line 152) an option to generate DV without the 10/100nits floor in 3-2 (madvr or hdr10plus to DV). This may cause invalid metadata in some occasion, always run the final rpu in metafier( now 2-7).
- Added an option to change DD+ 5.1 encoding bitrate and default is now 1024 because 1536 can cause issues on some players (max=1536)
- Added more languages support.
- Removed (8-5) hdr10plus injector extractor. you can inject with (1-1) and extract with (6-6)
- Merged (4-1-1) and (4-2). Simplified Mode 4. Now only have 3 options: STSL / STDL / DTDL. input can be any p7 file (mkv ts bdmv mpls etc..)
- Merged (3-2) and (3-3)
- changed the order in (8) and merged some audio workflows
- (Bugfix) MP4/MKV version: When mux_all_audio=NO and mux_all_sub=NO . The script was still muxing all the audio/subs
- (Bugfix) TS version: can now add silent core to more than one THD track, no longer just the main audio language.
azreil24
#9446 Post by azreil24 » Thu Jan 11, 2024 8:06 pm
Many thanks. You are correct, it's a 7.1 track :D
Forgot I could see the delay with Mediainfo, I manually found the delay and it seems I was right on the money with a 1.1s delay on my Hugo rip.
JCLG8
#9447 Post by JCLG8 » Thu Jan 11, 2024 8:09 pm
How can I convert a single track dual layer P7 mkv to dual track dual layer m2ts? And will the quality be the same after the conversion?
#9448 Post by RESET_9999 » Thu Jan 11, 2024 8:24 pm
In dovi_scripts TS version, workflow 4-3.
No quality loss.
azreil24
#9449 Post by azreil24 » Thu Jan 11, 2024 8:38 pm
The 8-2 flow created a 7.1 track with 1024kbps bit-rate, which seems to play fine in the LG TV's Kodi. Also, not sure if this Kodi is so smart, as otherwise I hate it with a passion, but seems the sound is in sync playing through it. Either it's that smart or it just happens that its usual delay is around 1 second, which is the delay required in my test case. I have a feeling it's the later. Through Zidoo I have the delay also.
#9450 Post by RESET_9999 » Thu Jan 11, 2024 8:56 pm
yes, 7.1 encoding with my the script is limited to 1024kbps.
It's the 5.1 encoding that can go up to 1536 and it stutter in Kodi so that's why you need the unreleased version of the script I just posted for those.
