for multi lenguage eng ita, audio e subtitle?
problem with Batman begins full bluray 1:1
advice
Re: advice
Does the version you have offer those languages? If so, you can extract them. The default setup for MakeMKV should pull all languages and put them into the mkv file.
But your message is rather terse on details.
Re: advice
Do you need to have Expert Mode enabled to be able to see all that stuff? I can never remember.
The Expert Mode checkbox is on the General tab in Preferences.
Marcello
Re: advice
I don't remember the settings for English and Italian to be chosen (loseless, lossy and subtitles)Woodstock wrote: Thu Jan 11, 2024 1:18 am Does the version you have offer those languages? If so, you can extract them. The default setup for MakeMKV should pull all languages and put them into the mkv file.
Re: advice
According to DVDCompare.net, there are several international releases for Batman Begins on blu-ray, including an Italian one.
https://www.dvdcompare.net/comparisons/film.php?fid=13366
It seems not all versions of the disc have an Italian soundtrack.
