JCLG8
#9406 Post by JCLG8 » Wed Jan 10, 2024 3:50 pm
RESET_9999 wrote:
Wed Jan 10, 2024 3:07 pm
JCLG8 wrote:
Wed Jan 10, 2024 2:50 pm
Hi, I recently bought a Sony X700. I am testing it with some of the test files particularly the eagle beak file and I am not sure if it's in LLDV or TV-LED. When it shows the chroma weight there is no change from the original shown before.
which TV ?
My LG C2 have a bug and Chroma weight is not working regardless of tv-led / player-led. It doesn't even work with the internal player.
Its a Panasonic GX800, a VA LCD from 2019.
#9407 Post by RESET_9999 » Wed Jan 10, 2024 3:53 pm
I dont know much about calibration (i paid someone to calibrate my TV) but maybe in TV-LED, only the internal TV DV configuration is used and the EDID target brightness is ignored?? And the EDID is only useful to the player when it does LLDV?
That would explain the odd result I see when I use high brightness TV-LED edid on my cheap 600nits vizio TV.
aboulfad
#9408 Post by aboulfad » Wed Jan 10, 2024 4:08 pm
DV calibration for LG TVs generates a file that you can load onto the TV. Although not recommended, I tried that calibration file in the past on my OLED. The Tmax in it must have been measured via calman & other required equipment.
Your theory that EDID info/LLDV player may make sense as those two entries are below Low Latency ...
Low Latency: Standard + Low Latency
Target Max Luminance: 350 cd/m^2
Target Min Luminance: 0.00099200 cd/m^2
quietvoid
#9409 Post by quietvoid » Wed Jan 10, 2024 4:49 pm
That is how it's supposed to work, the EDID is only used by external HDMI devices for detection/player-led.
Internally it's using the config file which is why it's always been preferred to have TV-led playback.
#9410 Post by RESET_9999 » Wed Jan 10, 2024 5:11 pm
thanks for confirming, it makes sense.
What is the internal config for tmax in our C2
JCLG8
#9411 Post by JCLG8 » Wed Jan 10, 2024 5:37 pm
which TV ?
Hi, sorry I posted twice on accident. You can look the model I wrote. A few posts up
aboulfad
#9412 Post by aboulfad » Wed Jan 10, 2024 5:41 pm
…What is the internal config for tmax in our C2
L o l, I thought that’s what EDID was reporting based on all the previous posts, back to square 0. It must be hidden in the TVs firmware. I don’t recall seeing anything in service menu or ez adjust of my E7.
#9413 Post by RESET_9999 » Wed Jan 10, 2024 6:02 pm
Since it's quite a old TV, it might not support TV-LED.
#9414 Post by RESET_9999 » Wed Jan 10, 2024 6:04 pm
https://github.com/chros73/bscpylgtv
JCLG8
#9415 Post by JCLG8 » Wed Jan 10, 2024 6:06 pm
Ah that sucks. Am I missing a lot if I can only use LLDV?
quietvoid
#9416 Post by quietvoid » Wed Jan 10, 2024 6:07 pm
It's apparently 810 nits AFAIK. 990 nits for the G2.
Mine measures around 815-825 nits IIRC.
aboulfad
#9417 Post by aboulfad » Wed Jan 10, 2024 6:11 pm
Interesting, maybe get calibration commands can tell us something. I didn’t calibrate my E7, I applied someone else’s calibration file. I’ll browse and see if there’s something there I can use on my 2017 E7 (nope I get asyncio.exceptions.TimeoutError, most likely doesn't work with older models).
#9418 Post by RESET_9999 » Wed Jan 10, 2024 6:23 pm
Not much since Chroma Weight is rarely used in real content.
https://drive.google.com/drive/u/1/fold ... KFJwFxnDt-
( I put ''chroma weight'' in the filename when I see one)
JCLG8
#9419 Post by JCLG8 » Wed Jan 10, 2024 6:32 pm
Ok thanks I'll check those out. I saw Vincent's video saying how the TV-LED is better because the colors are more accurate. But I have also seen comments here that that video doesn't mean much. Is TV-LED more accurate for the colors or does that video not matter?
#9420 Post by RESET_9999 » Wed Jan 10, 2024 6:53 pm
Better color mapping, maybe? but I wouldn't say LLDV has inaccurate colors as long as the player doesn't have bugs (shield red push) and Chroma Weight is not used by the colorist.
The difference shown in Vincent's video is definitely Chroma Weight and the Spears and Munsil montage he used is a VERY bright grade(4000+) which is not representative of the average Movie HDR grading (0-1000nits) so indeed, his video doesn't mean much for real content viewing.
