Thanks for the guide worked flawlessly with a BP60NB10.
The encoding part is the tricky part, but searching around this forum the information was present.
ELLEGARDEN777
Hello guys, I am writing to you because I need your help, wisdom and experience, I bought an external Blu ray reader from the BUFALLO BRUHD-PU3-BK brand. I told you that the device was working well, but suddenly it started reading discs discontinuously, when In the end, the LED stays red and the unit icon no longer appears on my PC. I have tried to solve it in every possible way but I have not been successful. I don't know if the device broke due to hardware failure or maybe it was something. with internal software files, I would greatly appreciate your help to solve this problem T_T
What happens if you unplug your drive, let it power down, wait for a couple minutes, then plug it back in?
Wild guess, this may be worth a shot. Disconnect the drive from USB, clear Not Connected USB devices using Nirsoft USBDeview (little portable app - no install), then reboot and reconnect the drive, see if that may help. You have to run USBDeview with admin rights (right-click USBDeview.exe and Run as administrator), then right click and "Uninstall Selected Device" on Not Connected USB devices. Not Connected USB Devices will be listed at the bottom of the shown USB history.ELLEGARDEN777 wrote: ↑Sat Jan 13, 2024 5:17 amI have tried to solve it in every possible way but I have not been successful. I don't know if the device broke due to hardware failure or maybe it was something.
Nirsoft USBDeview: (Scroll right down for download links)
https://www.nirsoft.net/utils/usb_devices_view.htmlWindows:
Identifying The Correct Title To Rip: Process Monitor Method - GetMPLS Method
Mux/Remux: Set A Subtitle Stream On By Default (Forced)
Hyperion_GB
Can I flash my BluRay Drive?
I have just been looking around and noticed that some BluRay drives are capable of being flashed to support 4K Ultra HD Disks. However, I am unsure if mine is compatible and if it is worth flashing or just buying a new drive that supports 4K disks. I am currently only using BluRay disks. However, if I can flash it would save me going out of my way to purchase a new drive.
Information that shows up in MakeMKV -
Drive Information:
Manufacturer: PIONEER
Product: BD-RW BDR-TD05
Revision: 3.00
Firmware Date: 2012-11-14
Bus Encryption flags: 1B
Highest AACS version: 66
LibreDrive Information:
Drive platform: Pioneer RS8211
Firmware version: ID74
If you have any insight and are able to assist me that would be great. I do not have high hopes of this working. However, it would be awesome if it did.
Thank you in advance!
Drive Information:
Revision: 3.00
That drive was built over three years before the specification for UHD existed, so it is "highly doubtful" it could be modified.Firmware Date: 2012-11-14
Hi
I can prove this.
Fully working.
This retail is sold as a drive with the cable, adapter, cable, a 25GB BD-R and with burning sw.
Bought in in Germany in a store today.
Verbatim 43888, source as displayed: BD-Re PIONEER BD-RW BDR-UD04 with FW 1,14
I can prove this.
Fully working.
lordbatwing
Re: Ultimate UHD Drives Flashing Guide Updated 2023 - Confirming Steps for BRUHD-PU3-BK
Hello!
I've been reading through the forums, and I purchased a drive per the guide.
I've drafted a plan for flashing my Buffalo BRUHD-PU3-BK. I would appreciate any corrections or validation before proceeding, particularly regarding the SDFtool values referenced at the bottom of the post (boot loader and firmware version). I've found the forums extremely helpful overall and really appreciate those who've contributed. Thanks in advance for the advice!
Plan:
1. Install MakeMKV and identify drive:
2. Download and extract SDFtool Flasher executable, updating for 4K screen per thread.
3. Download and extract firmware files per SDFtool Flasher thread.
4. Configure SDFtool Flasher with the following settings:
- Drive: `{path}: BUFFALO_Optical_Drive_BU14...`
- Drive metadata: MT1959 Platform ✔ | Encrypted Firmware ✔ | Include boot loader (?)
- Firmware: TBD (?)
(?) Seeking Clarity:
* I am unsure whether to include the boot loader per the SDFtool Flasher - UPDATE - 21/12/2021]
Plan:
OS device name: E:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BU14
Serial number: MO2N5DA3110
Firmware date: 2121-06-21 13:30
Bus encryption flags: 1F
- Firmware: TBD (?)
** I am unsure which firmware to choose based on Re: SDFtool Flasher and Re: BRUHD-PU3-PK BU12 to BU10?The latest version of the SDFtool Flasher has a checkbox option to flash the boot loader with the main firmware to the drive. This is useful for the newer BP50NB40 with SVC: NB52. It's also possible that other newer models may require this option later on. We will all work it out together as we go!!
BU40N 1.03-MK is the firmware to flash to first. If you want to flash another after that, such as BU40N 1.00 (for more software compatibility) you can.
1. HL-DT-ST-BD-RE_BU40N-BU12-OM01001-211902230922.bin
2. DE_Buffalo_BRUHD-PU3_BU10 OR DE_LG_BU40N_1.00
There's really no need to ever include the boot loader unless you've royally screwed up a flash.lordbatwing wrote: ↑Tue Jan 16, 2024 11:21 pmHello!
Plan:
1. Install MakeMKV and identify drive:2. Download and extract SDFtool Flasher executable, updating for 4K screen per thread.Code: Select all
Drive Information OS device name: E: Manufacturer: BUFFALO Product: Optical Drive Revision: BU14 Serial number: MO2N5DA3110 Firmware date: 2121-06-21 13:30 Bus encryption flags: 1F LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959
- Firmware: TBD (?)
* I am unsure whether to include the boot loader per the SDFtool Flasher - UPDATE - 21/12/2021]** I am unsure which firmware to choose based on Re: SDFtool Flasher and Re: BRUHD-PU3-PK BU12 to BU10?The latest version of the SDFtool Flasher has a checkbox option to flash the boot loader with the main firmware to the drive. This is useful for the newer BP50NB40 with SVC: NB52. It's also possible that other newer models may require this option later on. We will all work it out together as we go!!BU40N 1.03-MK is the firmware to flash to first. If you want to flash another after that, such as BU40N 1.00 (for more software compatibility) you can.1. HL-DT-ST-BD-RE_BU40N-BU12-OM01001-211902230922.bin
lordbatwing
Thank you @MartyMcNuts. I also went ahead and flashed it to `BU40N 1.03-MK` using the guidance in this post.MartyMcNuts wrote: ↑Wed Jan 17, 2024 3:26 amThere's really no need to ever include the boot loader unless you've royally screwed up a flash.
Thanks for the help!
Old Specs:
OS device name: E:
Revision: BU14
OS device name: E:
Revision: 1.03
Firmware version: 1.03
Hello
Is it possible to flash this one if the firmware is older than December 2022? Pioneer BDR-212EBK.
What tools and software do i need, if so?
Greetings
Greetings
joshrogers117
Product: BD-RW BDR-XS07U
Revision: 1.00
Serial number: SJDL003667JP
Firmware date: 2019-01-07
Firmware version: ID69
No disc insertedThanks!
hello ,
this has probably been asked already,
is there a good slot-in 9.5mm bluray drive that can do UHD or be made UHD friendly?
Jedi_Bolden
Hi All,
I'm a bit new here but I'm trying to flash a drive using my Mac. I thought I had successfully flashed a drive. See text from the terminal session I ran.
boldenamt@Allens-Mac-mini MacOS % ./makemkvcon f -d '/IOBDServices/72B3EF48' -f ~/Desktop/sdf.bin rawflash main -i ~/Desktop/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Reading input file /Users/boldenamt/Desktop/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MZFN1SJ4219
yes
100% Operation finished
Done successfully
After running this operation and opening MakeKKV, it still shows the drive is on Revision 1.02. Does anyone have any idea where I went wrong?
Any help appreciated. I'm using a archon MD-8107X-U3YC-UHD.
Thank you!!!!
yes
Done successfully
Thank you!!!!
- Screenshot 2024-01-20 at 17.29.23.png (122.86 KiB) Viewed 14577 times
