Re: SDFtool Flasher
No benefit
avian
Re: SDFtool Flasher
zaabs
Re: SDFtool Flasher
hey I just brought a BRUHD-PU3-BK wondering what firmware i flash
Re: SDFtool Flasher
BU40N 1.03-MK is the firmware to flash to first. If you want to flash another after that, such as BU40N 1.00 (for more software compatibility) you can.zaabs wrote: Tue Jan 09, 2024 12:55 am hey I just brought a BRUHD-PU3-BK wondering what firmware i flash
TylerBourbon
Re: SDFtool Flasher
Hi Marty,
I had a question as a newbie, I was about to flash my drive with the SDFtool, but I was curious what the difference was between write and read, I'm a bit uncertain. Is that referring to the burner drive and a non disc burning drive? Is there something else it means? I was searching the site and could find an answer.
zaabs
Re: SDFtool Flasher
this one DE_LG_BU40N_1.03_MK.bin because I dont see a file that has buffalo and that letter number combiniation in the filesMartyMcNuts wrote: Tue Jan 09, 2024 3:19 amBU40N 1.03-MK is the firmware to flash to first. If you want to flash another after that, such as BU40N 1.00 (for more software compatibility) you can.zaabs wrote: Tue Jan 09, 2024 12:55 am hey I just brought a BRUHD-PU3-BK wondering what firmware i flash
Re: SDFtool Flasher
Yepzaabs wrote: Tue Jan 09, 2024 10:57 amthis one DE_LG_BU40N_1.03_MK.bin because I dont see a file that has buffalo and that letter number combiniation in the filesMartyMcNuts wrote: Tue Jan 09, 2024 3:19 amBU40N 1.03-MK is the firmware to flash to first. If you want to flash another after that, such as BU40N 1.00 (for more software compatibility) you can.zaabs wrote: Tue Jan 09, 2024 12:55 am hey I just brought a BRUHD-PU3-BK wondering what firmware i flash
Re: SDFtool Flasher
No, lol. The read option copies the important bits of the firmware from the drive to a .tar file but it is not really needed these days.TylerBourbon wrote: Tue Jan 09, 2024 3:26 am Hi Marty,
The first post of this very thread explains each option.
crowdx42
Re: SDFtool Flasher
So I just bought a new LG drive:
Product: BD-RE WH16NS40
Revision: 1.05.
When I try to flash it I am seeing the error code 0xff056103?
I have tried both the DE_LG_WH16NS40-NS50_1.02.bin and the DE_LG_WH16NS60_1.02_MK.bin with no success.
Thoughts?
Patrick
Revision: 1.05.
Thoughts?
Patrick
Re: SDFtool Flasher
Ensure the drive tray is empty and closed. Your drive has encrypted firmware, so you should see a green tick for both "Drive Platform" and "Encrypted Firmware". You must flash WH16NS60 1.02-MK firmware first which removes the firmware encryption and is also the recommended firmware. After that, if you want to change to another firmware, you can.crowdx42 wrote: Fri Jan 12, 2024 10:33 pm So I just bought a new LG drive:
Revision: 1.05.
Thoughts?
Patrick
crowdx42
Re: SDFtool Flasher
It was the empty disk tray that caught me. Everything worked great when I removed the disk.
Thank you so much for the fast response and an excellent tool.
rajeevgeorge
Re: SDFtool Flasher
Hi
I am a newbie here, and tried to download and run the SDFtool Flasher. However, I get the following error:
"Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Object reference not set to an instance of an object."
Details
I apologise in advance for this long post. Any help will be welcome
Details
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation()
at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
System.Private.CoreLib
Assembly Version: 6.0.0.0
Win32 Version: n/a
CodeBase:
Assembly Version: 1.3.5.0
Win32 Version: n/a
CodeBase:
System.Runtime
Win32 Version: n/a
CodeBase:
Assembly Version: 6.0.2.0
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Common
Win32 Version: n/a
CodeBase:
System.Threading
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections
Win32 Version: n/a
CodeBase:
System.Diagnostics.Process
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Threading.Thread
Win32 Version: n/a
CodeBase:
Accessibility
Assembly Version: 4.0.0.0
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Numerics.Vectors
Win32 Version: n/a
CodeBase:
System.Memory
Win32 Version: n/a
CodeBase:
System.ComponentModel
Win32 Version: n/a
CodeBase:
System.Resources.Extensions
Win32 Version: n/a
CodeBase:
System.Drawing
Win32 Version: n/a
CodeBase:
System.ObjectModel
Win32 Version: n/a
CodeBase:
System.Linq
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections.Concurrent
Win32 Version: n/a
CodeBase:
mscorlib
Win32 Version: n/a
CodeBase:
Microsoft.Win32.SystemEvents
Win32 Version: n/a
CodeBase:
System.Collections.NonGeneric
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Private.Uri
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.ReaderWriter
Win32 Version: n/a
CodeBase:
System.Private.Xml
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Net.WebClient
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.XmlSerializer
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Registry
Win32 Version: n/a
CodeBase:
System.Runtime.Loader
Win32 Version: n/a
CodeBase:
System.Diagnostics.StackTrace
Win32 Version: n/a
CodeBase:
System.Reflection.Metadata
Win32 Version: n/a
CodeBase:
System.Collections.Immutable
Win32 Version: n/a
CodeBase:
************** JIT Debugging **************-
Re: SDFtool Flasher
Do you have MakeMKV installed in the default location?rajeevgeorge wrote: Tue Jan 16, 2024 4:52 pm Hi
Details
I apologise in advance for this long post. Any help will be welcomeCode: Select all
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation() at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** System.Private.CoreLib Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- SDFtool Flasher Assembly Version: 1.3.5.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Runtime Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Windows.Forms Assembly Version: 6.0.2.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Windows.Forms.Primitives Assembly Version: 6.0.2.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.ComponentModel.Primitives Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Runtime.InteropServices Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Drawing.Primitives Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Collections.Specialized Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Drawing.Common Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Threading Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Diagnostics.TraceSource Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Collections Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Diagnostics.Process Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- Microsoft.Win32.Primitives Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.ComponentModel.EventBasedAsync Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Threading.Thread Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- Accessibility Assembly Version: 4.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.ComponentModel.TypeConverter Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Numerics.Vectors Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Memory Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.ComponentModel Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Resources.Extensions Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Drawing Assembly Version: 6.0.2.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.ObjectModel Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Linq Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Runtime.Serialization.Formatters Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Collections.Concurrent Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- mscorlib Assembly Version: 4.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- Microsoft.Win32.SystemEvents Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Collections.NonGeneric Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Configuration.ConfigurationManager Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Runtime.InteropServices.RuntimeInformation Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Private.Uri Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Security.Cryptography.Algorithms Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Security.Cryptography.Primitives Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Xml.ReaderWriter Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Private.Xml Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Text.RegularExpressions Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Net.WebClient Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Text.Encoding.Extensions Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Xml.XmlSerializer Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- Microsoft.Win32.Registry Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Runtime.Loader Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Diagnostics.StackTrace Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Reflection.Metadata Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Collections.Immutable Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- ************** JIT Debugging **************
publisher1949
Re: SDFtool Flasher
I have an LG WH14NS0 that came with ver 1.05. Is there a way to restore a drive if I dumped the ROM before flashing?
Re: SDFtool Flasher
Not using that dump as it only contains the important bits such as cal data.publisher1949 wrote: Sun Jan 21, 2024 4:06 pm I have an LG WH14NS0 that came with ver 1.05. Is there a way to restore a drive if I dumped the ROM before flashing?
You didn't say what model it is. Is it a WH14NS40 or WH14NS60? Anyway, if you need to return it, you can restore the drive by flashing a lower version such as 1.02-MK, 1.03-MK or 1.04-MK, depending on which is available for your drive model in the MK firmware pack then using the original LG flasher pertaining to your drive model from here: viewtopic.php?f=16&t=24443
