I don't quite understand what you mean. But as far as I know you can read EDID with the utility https://entechtaiwan.com/util/moninfo.shtm.
Although I haven't tried it myself.
Thanks I'll check out that tool. At 1'39" of your video, there's a black info overlay but now that I look at it, it seems maybe from your capture card (would you mind sharing which card ?). I thought it showed EDID but actually has lots of video signal properties.DMDreview wrote: Tue Jan 09, 2024 1:51 pm I don't quite understand what you mean. But as far as I know you can read EDID with the utility https://entechtaiwan.com/util/moninfo.shtm.
Now understood. this very good site with edid decoder https://hverkuil.home.xs4all.nl/edid-de ... ecode.htmlaboulfad wrote: Tue Jan 09, 2024 2:15 pmThanks I'll check out that tool. At 1'39" of your video, there's a black info overlay but now that I look at it, it seems maybe from your capture card (would you mind sharing which card ?). I thought it showed EDID but actually has lots of video signal properties.DMDreview wrote: Tue Jan 09, 2024 1:51 pm I don't quite understand what you mean. But as far as I know you can read EDID with the utility https://entechtaiwan.com/util/moninfo.shtm.
That's also helpful but not what I am asking about. I was asking how did you get EDID info from your TV. I thought wrongly that signal info showed it in your video. RESET_9999 explained few pages ago & I wondered if you were using the raspberry pi/Pgenerator. We can for now "forget about it" : )DMDreview wrote: Tue Jan 09, 2024 2:44 pm ...Now understood. this very good site with edid decoder https://hverkuil.home.xs4all.nl/edid-de ... ecode.html
device from hdfury can read ad save edid from tvaboulfad wrote: Tue Jan 09, 2024 2:53 pmThat's also helpful but not what I am asking about. I was asking how did you get EDID info from your TV. I thought wrongly that signal info showed it in your video. RESET_9999 explained few pages ago & I wondered if you were using the raspberry pi/Pgenerator. We can for now "forget about it" : )DMDreview wrote: Tue Jan 09, 2024 2:44 pm ...Now understood. this very good site with edid decoder https://hverkuil.home.xs4all.nl/edid-de ... ecode.html
PS: That moninfo tool didn't show anything useful (EDID) when I connected my Bootcamp/Mac to my LGTV via HDMI.
Try to download your edid with CRU:aboulfad wrote: Tue Jan 09, 2024 2:53 pm
That's so funny, I just finished doing that but didn't find anything useful related to DV or HDR... I think it seems CRU depends on the GPU on the laptop (MacBook Pro 2018 i7, Intel Iris Plus Graphics 655) or the USB-C to HDMI Anker adapter , but unsure ! Grrr can't attach .txt ... or is it a quota issue.RESET_9999 wrote: Tue Jan 09, 2024 5:24 pm Try to download your edid with CRU:
https://www.monitortests.com/forum/Thre ... tility-CRU
What is the size of the original EDID file, it feels like it is without the second 128 bytes. the size of the full EDID is 256 bytes.aboulfad wrote: Tue Jan 09, 2024 5:29 pmThat's so funny, I just finished doing that but didn't find anything useful related to DV or HDR... I think it seems CRU depends on the GPU on the laptop (MacBook Pro 2018 i7, Intel Iris Plus Graphics 655) or the USB-C to HDMI Anker adapter , but unsure ! Grrr can't attach .txt ... or is it a quota issue.RESET_9999 wrote: Tue Jan 09, 2024 5:24 pm Try to download your edid with CRU:
Here's a LINK to that text file decoded from the site that @DMDreview shared.
That is what I exported from CRU & decoded by that site, idk what you mean by original file unless the .bin file which is also 128bytes.DMDreview wrote: Tue Jan 09, 2024 6:04 pm What is the size of the original EDID file, it feels like it is without the second 128 bytes. the size of the full EDID is 256 bytes.
full edid BIN =256 bytes. You need read full EDID with extended dataaboulfad wrote: Tue Jan 09, 2024 6:17 pmThat is what I exported from CRU & decoded by that site, idk what you mean by original file unless the .bin file which is also 128bytes.DMDreview wrote: Tue Jan 09, 2024 6:04 pm What is the size of the original EDID file, it feels like it is without the second 128 bytes. the size of the full EDID is 256 bytes.
Extension blocks:
GPU-specific limtations:
CRU can read extension blocks from displays connected to AMD and NVIDIA GPUs.
CRU can't read extension blocks with Intel GPUs or switchable graphics.
Older drivers or GPUs may only support up to 3 extension blocks.
No need to worry about your TV edid. LG OLED65E7P is about ~700nits.aboulfad wrote: Tue Jan 09, 2024 6:29 pm ^^^ Understood, though CRU has these following limitations & my MBP 2018 has most likely a dum & unsupported GPU. Oh RESET just discovered the mystery![]()
Thank you, I knew that from other users DV calibration files, was just curious how to retrieve EDID without vertex HW.susanstone2022 wrote: Wed Jan 10, 2024 12:32 am No need to worry about your TV edid. LG OLED65E7P is about ~700nits.
I'll test this week and let you know. It would be amazing if it also can do lossless audio (I doubt it though based on others' experiences so far).RESET_9999 wrote: Tue Jan 09, 2024 12:20 pmYes, I guess the ST P7 MKV would work on the C9 kodi app. Let us know if you try.speeddemon wrote: Tue Jan 09, 2024 8:40 am Would this be able to play MKVs on my C9 that are Profile 7 FEL?
