aboulfad
Post by aboulfad » Tue Jan 09, 2024 11:26 am
DMDreview wrote:
Tue Jan 09, 2024 10:17 am
It would be nice to decode back from the binary code of the RPU video to see what changes there specifically. But I don't know how to do that
if I understand what you’re asking, you can use dovi tool to convert (export or info) RPU.bin or specific frames to json, lots of ‘low level ‘DV RPU info in there.
DMDreview
Post by DMDreview » Tue Jan 09, 2024 11:31 am
No, I physically see the RPU binary code in the ycbcr data video stream.
here's my video of what I'm talking about and how it looks from the TV and player's point of view.
(watch with English subtitles)
https://youtu.be/eQ9SOMlX0AI?feature=shared
aboulfad
Post by aboulfad » Tue Jan 09, 2024 11:54 am
Ah you want to capture then view the extracted RPU from the DV bitstream sent from a player. In that interesting video (hard to follow as its subtitles were TTS), he somehow captured the video stream via a capture card & is viewing it using DaVinci ? Since it's TV-led, I think the TV-Led video signal (DV) is tunnelled over HDMI via RGB 8-bit so I am guessing any 4K video capture card can do the job but I am unsure.
Odd, your username is the same as that YT video's channel ... Oh darn, are you the author of that YT channel & that video you shared above ?
The conclusion in that video summarizes what you're asking about, sorry way above my pay grade but very interesting video, thanks for sharing :)
Post by RESET_9999 » Tue Jan 09, 2024 12:20 pm
speeddemon wrote:
Tue Jan 09, 2024 8:40 am
Would this be able to play MKVs on my C9 that are Profile 7 FEL?
Yes, I guess the ST P7 MKV would work on the C9 kodi app. Let us know if you try.
LV8HD wrote:
Tue Jan 09, 2024 10:30 am
@RESET_9999 Has this ever been fixed? viewtopic.php?f=12&t=26034
no idea
DMDreview
Post by DMDreview » Tue Jan 09, 2024 12:32 pm
Yes, I am the author. :)
I will try to make a translation for this video in English, I agree that it is hard to read subtitles and try to understand what is happening on the screen. auto speech translation misinterprets words, changes the meaning a lot.
And about decoding RPU from the video, I think it is possible if there is no encryption. But it's complicated.
susanstone2022
Post by susanstone2022 » Tue Jan 09, 2024 12:47 pm
RESET_9999 wrote:
Fri Dec 29, 2023 5:45 pm
ok, I'm starting to understand what's going on with the different RPU responses on players in TV-LED and in LLDV. It seems the x700/x800m2 almost completely ignores L1 and always tone map to the TV edid target.
Yes, oppo and all bluray UHD players change the PRU in TV-LED mode. they change the data from the RPU and then it goes to the TV.
Shield tv does not touch the PRU.
I will show in a video soon how it looks like in the video data from the RPU.
does this mean bluray UHD players should also be categorized as 'fake TV-led'?
aboulfad
Post by aboulfad » Tue Jan 09, 2024 1:17 pm
Yes, I am the author. :) ...
Is the EDID info shown using the TV itself or some other method (Pgenerator on rpi mentioned by RESET) ?
DMDreview
Post by DMDreview » Tue Jan 09, 2024 1:43 pm
No, the TV still does the processing, but UHD players give it some hints based on EDID data from the TV itself.
DMDreview
Post by DMDreview » Tue Jan 09, 2024 1:51 pm
I don't quite understand what you mean. But as far as I know you can read EDID with the utility https://entechtaiwan.com/util/moninfo.shtm.
Although I haven't tried it myself.
aboulfad
Post by aboulfad » Tue Jan 09, 2024 2:15 pm
Thanks I'll check out that tool. At 1'39" of your video, there's a black info overlay but now that I look at it, it seems maybe from your capture card (would you mind sharing which card ?). I thought it showed EDID but actually has lots of video signal properties.
DMDreview
Post by DMDreview » Tue Jan 09, 2024 2:44 pm
Now understood. this very good site with edid decoder https://hverkuil.home.xs4all.nl/edid-de ... ecode.html
aboulfad
Post by aboulfad » Tue Jan 09, 2024 2:53 pm
...Now understood. this very good site with edid decoder https://hverkuil.home.xs4all.nl/edid-de ... ecode.html
That's also helpful but not what I am asking about. I was asking how did you get EDID info from your TV. I thought wrongly that signal info showed it in your video. RESET_9999 explained few pages ago & I wondered if you were using the raspberry pi/Pgenerator. We can for now "forget about it" : )
PS: That moninfo tool didn't show anything useful (EDID) when I connected my Bootcamp/Mac to my LGTV via HDMI.
DMDreview
Post by DMDreview » Tue Jan 09, 2024 3:11 pm
device from hdfury can read ad save edid from tv
Post by RESET_9999 » Tue Jan 09, 2024 5:24 pm
Try to download your edid with CRU:
https://www.monitortests.com/forum/Thre ... tility-CRU
aboulfad
Post by aboulfad » Tue Jan 09, 2024 5:29 pm
That's so funny, I just finished doing that but didn't find anything useful related to DV or HDR... I think it seems CRU depends on the GPU on the laptop (MacBook Pro 2018 i7, Intel Iris Plus Graphics 655) or the USB-C to HDMI Anker adapter , but unsure ! Grrr can't attach .txt ... or is it a quota issue.
Here's a LINK to that text file decoded from the site that @DMDreview shared.
