Makemkv failed on bluray !!!
cbrpaul
Post by cbrpaul »
Hi all,
I have been using makemv for to put my personal dvd collection onto my network at home, 8)
I was so impressed with it , that i decided to buy a bluray player and do the same for my bluray personal collection , however i got a problem as per below !!
Does this mean i cant put my bluray collection onto the network ???
may thx
Paul
MakeMKV v1.6.12 win(x86-release) started
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?mpqamppPtaeeG+...
Icetrips
Re: Makemkv failed on bluray !!!
Post by Icetrips »
Hi cbrpaul,
What did you mean by "bluray collection"?
Did your disk is a original bluray or a decrypted one or burned one?
MakeMKV is used with original bluray containing protection.
Original Bluray disk.. a encrypted and standard, this could be not the case of other Bluray disk.
If you used a program like DVDFab, be sure your Bluray video aren't standard, so MakeMKV doesn't support it.
If you already remove the protected... there is no point using MakeMKV, just look for m2ts file directly on the disk.
MakeMKV registered
System: Windows 7 x64 SP1, LG WH10LS30
Playback Devices: Media Player Classic, Samsung DLNA
cbrpaul
Post by cbrpaul »
hi,
thankyou for your reply
I have an original bluray that i purchased from a shop
This is the first time i have tried to back up a bluray with makemkv , i tried it the same way as i ahve with my dvd,s
Am i doing something wrong ?
Please advise , or point me in the right direction for " how to rip blurays" info
I just paid ?40 for a USB external bluray player to bsck up my purchased bluray collection , i hope its not a waste of money :(
many thx
Paul
reebok
Post by reebok »
aacs encryption isn't supported by makemkv yet. there is a long thread about it here and it is supposed to be fixed soon:
http://www.makemkv.com/forum2/viewtopic.php?f=8&t=3559
cbrpaul
Post by cbrpaul »
Thx for the info
Romansh
Post by Romansh »
reebok wrote:aacs encryption isn't supported by makemkv yet. there is a long thread about it here and it is supposed to be fixed soon:
That thread is about AACS bus encryption, not AACS. AACS is obviously supported, but it's periodically updated - and MakeMKV needs to be updated as well to be able to support the newer version of AACS:
http://www.makemkv.com/download/ wrote:MakeMKV v1.6.10
Added support for AACS v25
Fixed MKV multiplexing error introduced in 1.6.9
