I keep getting this on app opening on several different computers, Because of it I cant open any UHD discs either, even ones I've ripped before.
Any ideas on what I can do to fix this?
Automatic SDF downloading is disabled or failed.
madaaron
Re: Automatic SDF downloading is disabled or failed.
If you haven't shut it down yourself, it is likely that your computer has something disabling it. The host it is downloaded from is in a domain that is blocked by many DNS servers (cloudflare is one of them).
You can check this topic for more information.
madaaron
I am using cloudflare as my DNS, thanks for that info
madaaron
It seems that wasn't the issue, I have tried what was suggested in that link and followed to the T in the host file edit with notepad ++ and still no go with reaching that dns. I have disabled cloudflare in my Router setup and am using the default settings. I have tried using my hotspot on my phone. I do not use any web security either like bit defender etc., This has me baffled to no end
The next thing to try is to use a VPN. You might have to try a few different exit points until you find one that works. I've seen people say they've had luck with exit points in Asia.
Since MakeMKV keeps a local copy of the hashed keys it downloads, you would only need to use the VPN when you need MakeMKV to download additional hashed keys.
madaaron
Thanks ill give that a shot
