First conversion problem
is14fun
#1 Post by is14fun » Tue Aug 18, 2009 9:45 pm
On my first conversion, I got this MakeMKV BETA popup alert: The size of output file 'G/My Movies/title)).mkv' may reach as much as 5496 megabytes while target filesystem has a file size limit of 4095 megabytes. Do you still want to continue (title will be skipped)? If I say yes I get a message saying copy complete. 0 titles saved. If I say no, nothing happens. How to I get arount this problem??
Bling2Ming
Re: First conversion problem
#2 Post by Bling2Ming » Wed Aug 19, 2009 5:30 am
The FAT32 file system has a maximum file size of 4GB. If you want to rip this disk successfully with Makemkv you will need to format the hard disk partition onto which you rip, (the target file system) to the NTFS file system.
is14fun
#3 Post by is14fun » Wed Aug 19, 2009 7:06 pm
Made the conversion, ran MakeMKV and got this:
MakeMKV v1.4.6 beta win(x86-release) started
Debug logging enabled, log will be saved as C:\Documents and Settings\Robert Jameson/MakeMKV_log.txt
FAILURE: Code 49 at o9KTzxA0Z`r$,p]y:29400002
FAILURE: Code 0 at o9KTzxA0Z`r$,p]y:29399910
Opening files on harddrive at G:/My Movies/THE WEDDING PLANNER/MainMovie/DVD_VIDEO/VIDEO_TS/
Complex multiplex encountered - 31 cells and 12429 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #0 was added (31 cell(s), 1:43:31)
Operation sucessfully completed
Saving 1 titles into directory G:/My Movies
FAILURE: Code 224 at J>waNuq@Ex?2uBWD9wRp$:29394965
FAILURE: Code 49 at [Ph>Xo\vo{y421s!9m,:213133365
FAILURE: Code 0 at J>waNuq@Ex?2uBWD9wRp$:121264211
Failed to save title 0 to file G:/My Movies/title00.mkv
0 titles saved, 1 failed
Not sure what is going on. Don't know how to upload log file as I get error message saying I connot use txt format. Do have it if it is needed by anyone. Help please. I did convert one DVD suscessfully this is all I get on the second one.
kryzchek
#4 Post by kryzchek » Thu Aug 20, 2009 7:23 pm
Did you even read Bling2Ming's reply? Your Windows OS is using a Fat32 file system which cannot handle files over 4GB in size. If your first DVD was converted successfully, it's probably because it was under 4GB in size, or you saved it to an NTFS partition.
is14fun
#5 Post by is14fun » Thu Aug 20, 2009 11:37 pm
Thanks for your reply, have made conversion and all is well. Thanks again!!
