I have been ripping my DVD and Bluray collection using MAKEMKV and it has been working great on my HDI Dune Smart D1. Ever since I upgraded to version 1.6.12 from 1.6.10 my Dune player is unable play the files created with 1.6.12. The files play fine with VLC but not on the Dune. I would like to roll back to version 1.6.10 but I can't find a link to the file, the previous version section has version 1.6.8 which will not function, I get an error saying this version is too old. Any Ideas?
HDI Dune can't play MKV from version 1.6.12
mattmullen@me.com
Re: HDI Dune can't play MKV from version 1.6.12
I have a Dune Base 3.0 and a few Smart H1's in my house and I have had no problems playing back MKVs made by MakeMKV 1.6.12.
- Contact:
To use 1.6.8 , install 1.6.12 into separate folder, enter current beta key or your key in 1.6.12. After that you can use 1.6.8 on the same computer. However I'm surprised that you have problems with 1.6.12 - can you post a mediainfo output of problematic MKV file?mattmullen@me.com wrote:the previous version section has version 1.6.8 which will not function, I get an error saying this version is too old. Any Ideas?
mattmullen@me.com
Here are 2 different MediaInfo files 300 Plays fine made with MakeMKV 1.6.10 Cars gives an error that the file is unsupported made with v1.1.12
- Contact:
There were pretty much zero DVD-related changes between 1.6.10 and 1.6.12 . Please try to remux the file from 1.6.12 with mkvmerge mmg and see if it will become playable.
