The Thing 1CD9 Dump
ward_prescott
The Thing 1CD9 Dump
#1 Post by ward_prescott » Wed Dec 27, 2023 8:44 am
Sent MKB20_v76_The_Thing_1CD9.tgz. Thanks!
ward_prescott
Re: The Thing 1CD9 Dump
#2 Post by ward_prescott » Wed Jan 03, 2024 11:01 am
This is now working.
allaboutsound
#3 Post by allaboutsound » Sat Jan 06, 2024 6:44 am
I'm having issues with The Thing 4k UHD. It will burn about 30% and then get stuck. Do I need to reinstall MakeMKV for an update if this was fixed in a patch?
#4 Post by Woodstock » Sat Jan 06, 2024 2:21 pm
The question is, "Why did it stop?"
Most likely cause is a problem with the disk. Logs tell a lot about this, but you presented none.
allaboutsound
#5 Post by allaboutsound » Sat Jan 06, 2024 4:39 pm
Sorry, I have attached multiple logs below. On another note, how do I provide a dump file and where do I send them? I couldn't find a sticky on the forum regarding that. I'm going to clean the disc with alcohol/water and a microfiber when I get back home to see if that fixes it too.
Here's a log of opening the disc:
MakeMKV v1.17.5 win(x64-release) started
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Downloading latest HK to C:\Users\[USERNAME]/.MakeMKV ...
Using Java runtime from C:\Program Files (x86)\Java\jre-1.8\bin\java.exe
File 00156.mpls was added as title #0
File 00157.mpls was added as title #1
Title #00600.mpls has length of 24 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00030.mpls was added as title #2
Title #00152.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00004.mpls has length of 14 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00005.mpls has length of 14 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00006.mpls has length of 14 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00010.mpls has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00012.mpls was added as title #3
Title #00100.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00110.mpls was added as title #4
File 00111.mpls was added as title #5
File 00112.mpls was added as title #6
File 00113.mpls was added as title #7
File 00114.mpls was added as title #8
File 00115.mpls was added as title #9
File 00116.mpls was added as title #10
File 00117.mpls was added as title #11
File 00118.mpls was added as title #12
File 00119.mpls was added as title #13
File 00144.mpls was added as title #14
File 00145.mpls was added as title #15
File 00120.mpls was added as title #16
File 00121.mpls was added as title #17
File 00122.mpls was added as title #18
File 00123.mpls was added as title #19
File 00124.mpls was added as title #20
File 00125.mpls was added as title #21
File 00126.mpls was added as title #22
File 00127.mpls was added as title #23
File 00128.mpls was added as title #24
File 00129.mpls was added as title #25
File 00142.mpls was added as title #26
File 00143.mpls was added as title #27
File 00130.mpls was added as title #28
File 00131.mpls was added as title #29
File 00132.mpls was added as title #30
File 00133.mpls was added as title #31
File 00134.mpls was added as title #32
File 00135.mpls was added as title #33
File 00136.mpls was added as title #34
File 00137.mpls was added as title #35
File 00138.mpls was added as title #36
File 00139.mpls was added as title #37
File 00140.mpls was added as title #38
File 00141.mpls was added as title #39
File 00146.mpls was added as title #40
File 00147.mpls was added as title #41
File 00148.mpls was added as title #42
File 00801.mpls was added as title #43
Title #00007.mpls has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00009.mpls has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00008.mpls has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00844.mpls was added as title #44
Title #00877.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00878.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00879.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00101.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00102.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00103.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00104.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00105.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00106.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00107.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00108.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00109.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01208.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01209.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01210.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01211.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01212.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01213.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01214.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01215.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01216.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01217.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01218.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01219.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01220.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01221.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01222.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01223.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01224.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01225.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01226.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01227.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01228.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01229.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01230.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01231.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01232.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01233.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01234.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01235.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01236.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #01237.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 01238.mpls was added as title #45
File 01239.mpls was added as title #46
File 01240.mpls was added as title #47
Title 00800.mpls is equal to title 00801.mpls and was skipped
File 00149.mpls was added as title #48
Title #00020.mpls has length of 24 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00003.mpls has length of 24 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00011.mpls has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title 00011.mpls(1) is equal to title 00012.mpls and was skipped
Title #00841.mpls has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00842.mpls has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00843.mpls has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00165.m2ts has length of 24 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00178.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00246.m2ts has length of 14 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00247.m2ts has length of 14 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00248.m2ts has length of 14 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00252.m2ts has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00293.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00249.m2ts has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00251.m2ts has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00250.m2ts has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00365.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00366.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00367.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00435.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00436.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00437.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00438.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00439.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00440.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00441.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00442.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00443.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00444.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00445.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00446.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00447.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00448.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00449.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00450.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00451.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00452.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00453.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00454.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00455.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00456.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00457.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00458.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00459.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00460.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00461.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00462.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00463.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00464.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00465.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00466.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00467.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00468.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00469.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00470.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00471.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00472.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Saving 1 titles into directory D:/Video/The Thing
Here's what I got from doing a file backup:
Backing up disc into folder "D:/Video/backup/THE_THING"
File "/dummy_f.dat" was skipped
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '9789044736'
Failed to save title /BDMV/STREAM/00294.m2ts to file D:/Video/backup/THE_THING/BDMV/STREAM/00294.m2ts
Encountered 10 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup done but 1 files failed hash check
And from attempting a makemkv from disc:
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '10325784576'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '10325981184'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '10325981184'
And my drive info:
OS device name: G:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLQN8I91102
Highest AACS version: 77
Firmware version: 1.02
Disc Information
Label: THE_THING
Timestamp: 2021-07-15 16:09:05
Protection: AACS2.0/C v76
Data capacity: 84.33 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
#6 Post by Woodstock » Sat Jan 06, 2024 6:55 pm
A number of issues show in the log. First is:
This usually means something is blocking your computer from getting new keys. Sometimes this is a DNS issue, which is discussed here.
This can mean several things. If the location is consistent, it usually points to an error on the disk in a fixed location. If it moves around on different runs, it may be an issue where the drive is starting to move faster than it has power to do (most often on USB-powered drives), which is a separate issue.
allaboutsound
#7 Post by allaboutsound » Sat Jan 06, 2024 7:04 pm
Thanks Woodstock.
I have a feeling it might be the HK issue. I added the necessary info to the host file in system32 but it still fails. I probably need a vpn but have never used one for this. Do I need to put info into the proxy server field in prefs? Sorry, I am still a bit new to this.
allaboutsound
#8 Post by allaboutsound » Sun Jan 07, 2024 2:20 am
Got a VPN up and running and that did allow me to download HK's. Fingers crossed The Thing successfully rips.
allaboutsound
#9 Post by allaboutsound » Sun Jan 07, 2024 3:08 am
No luck, HK's didn't seem to do the trick. It's either a disc or drive issue at this point. I am going to return the movie and get another one and I'm looking to get a pioneer drive as well to see if that will fix it.
