avian
Re: SDFtool Flasher
Post by avian » Sat Jan 06, 2024 1:07 pm
I've got a Slim LG-BP50NB40 with SVC CODE: NB52. I followed the "Ultimate UHD Drives Flashing Guide Updated 2023" guide, and did the suggested "NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty" procedure.
So I'm on BP60N10 1.0 HBD firmware now, and its working great. But then I came across this thread, which says "(FYI, the HBD firmware for BP50NB40 is now obsolete as SDFtool Flasher can flash the BP50NB40/WP50NB40 and BP60NB10 drives)".
Is there a benefit in me moving to one of the non hybrid firmwares mentioned above? Is one firmware preferred over the other? And if I were to move to one of those other non hybrid firmwares, what would the best way to do it be (i.e. guessing using the command line with no enc and no full)? Or would I need to use SDFtool Flasher instead ?
Re: SDFtool Flasher
Post by Billycar11 » Sat Jan 06, 2024 7:10 pm
No benefit
avian
Re: SDFtool Flasher
Post by avian » Sun Jan 07, 2024 10:46 am
Billycar11 wrote: Sat Jan 06, 2024 7:10 pm No benefit
zaabs
Re: SDFtool Flasher
Post by zaabs » Tue Jan 09, 2024 12:55 am
hey I just brought a BRUHD-PU3-BK wondering what firmware i flash
Re: SDFtool Flasher
Post by MartyMcNuts » Tue Jan 09, 2024 3:19 am
zaabs wrote: Tue Jan 09, 2024 12:55 am hey I just brought a BRUHD-PU3-BK wondering what firmware i flash
BU40N 1.03-MK is the firmware to flash to first. If you want to flash another after that, such as BU40N 1.00 (for more software compatibility) you can.
TylerBourbon
Re: SDFtool Flasher
Post by TylerBourbon » Tue Jan 09, 2024 3:26 am
Hi Marty,
I had a question as a newbie, I was about to flash my drive with the SDFtool, but I was curious what the difference was between write and read, I'm a bit uncertain. Is that referring to the burner drive and a non disc burning drive? Is there something else it means? I was searching the site and could find an answer.
zaabs
Re: SDFtool Flasher
Post by zaabs » Tue Jan 09, 2024 10:57 am
MartyMcNuts wrote: Tue Jan 09, 2024 3:19 am
this one DE_LG_BU40N_1.03_MK.bin because I dont see a file that has buffalo and that letter number combiniation in the files
Re: SDFtool Flasher
Post by MartyMcNuts » Tue Jan 09, 2024 9:55 pm
zaabs wrote: Tue Jan 09, 2024 10:57 am
Yep
Re: SDFtool Flasher
Post by MartyMcNuts » Tue Jan 09, 2024 9:59 pm
TylerBourbon wrote: Tue Jan 09, 2024 3:26 am Hi Marty,
No, lol. The read option copies the important bits of the firmware from the drive to a .tar file but it is not really needed these days.
The first post of this very thread explains each option.
crowdx42
Re: SDFtool Flasher
Post by crowdx42 » Fri Jan 12, 2024 10:33 pm
So I just bought a new LG drive:
Product: BD-RE WH16NS40
Revision: 1.05.
When I try to flash it I am seeing the error code 0xff056103?
I have tried both the DE_LG_WH16NS40-NS50_1.02.bin and the DE_LG_WH16NS60_1.02_MK.bin with no success.
Thoughts?
Patrick
Re: SDFtool Flasher
Post by MartyMcNuts » Sat Jan 13, 2024 4:34 am
crowdx42 wrote: Fri Jan 12, 2024 10:33 pm So I just bought a new LG drive:
Revision: 1.05.
Thoughts?
Patrick
Ensure the drive tray is empty and closed. Your drive has encrypted firmware, so you should see a green tick for both "Drive Platform" and "Encrypted Firmware". You must flash WH16NS60 1.02-MK firmware first which removes the firmware encryption and is also the recommended firmware. After that, if you want to change to another firmware, you can.
crowdx42
Re: SDFtool Flasher
Post by crowdx42 » Sat Jan 13, 2024 5:05 am
It was the empty disk tray that caught me. Everything worked great when I removed the disk.
Thank you so much for the fast response and an excellent tool.
rajeevgeorge
Re: SDFtool Flasher
Post by rajeevgeorge » Tue Jan 16, 2024 4:52 pm
Hi
I am a newbie here, and tried to download and run the SDFtool Flasher. However, I get the following error:
"Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Object reference not set to an instance of an object."
Details
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation()
   at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
System.Private.CoreLib
    Assembly Version: 6.0.0.0
    Win32 Version: n/a
    CodeBase:
    Assembly Version: 1.3.5.0
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
    Assembly Version: 6.0.2.0
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing.Primitives
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing.Common
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
System.Diagnostics.Process
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.Primitives
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading.Thread
    Win32 Version: n/a
    CodeBase:
Accessibility
    Assembly Version: 4.0.0.0
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Numerics.Vectors
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
System.ComponentModel
    Win32 Version: n/a
    CodeBase:
System.Resources.Extensions
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections.Concurrent
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.SystemEvents
    Win32 Version: n/a
    CodeBase:
System.Collections.NonGeneric
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Xml.ReaderWriter
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Net.WebClient
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Xml.XmlSerializer
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.Registry
    Win32 Version: n/a
    CodeBase:
System.Runtime.Loader
    Win32 Version: n/a
    CodeBase:
System.Diagnostics.StackTrace
    Win32 Version: n/a
    CodeBase:
System.Reflection.Metadata
    Win32 Version: n/a
    CodeBase:
System.Collections.Immutable
    Win32 Version: n/a
    CodeBase:
************** JIT Debugging **************
I apologise in advance for this long post. Any help will be welcome
Re: SDFtool Flasher
Post by MartyMcNuts » Tue Jan 16, 2024 10:02 pm
rajeevgeorge wrote: Tue Jan 16, 2024 4:52 pm Hi
Details
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
Accessibility
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
Do you have MakeMKV installed in the default location?
publisher1949
Re: SDFtool Flasher
Post by publisher1949 » Sun Jan 21, 2024 4:06 pm
I have an LG WH14NS0 that came with ver 1.05. Is there a way to restore a drive if I dumped the ROM before flashing?
