Lost UHD support on flashed drive
knyght1
Post by knyght1 » Fri Jan 05, 2024 6:10 pm
Any reason I suddenly lost the ability to read UHD on a flashed drive? Never had an issue until recently (Oppenheimer & Mission Impossible 7). And I tried multiple discs for each. Won't recognize the disc at all. Just spins and eventually ejects the disc.
Product: BD-RE WH16NS60
Revision: 1.00
Serial number: M6AJ3MK1329
Firmware date: 2117-04-25 17:56
Highest AACS version: 81
Firmware version: 1.00
Re: Lost UHD support on flashed drive
Post by d00zah » Fri Jan 05, 2024 6:35 pm
If external, power down the drive for ~a minute.
If internal, power down the PC for ~a minute.
Restore power & retry.
knyght1
Post by knyght1 » Fri Jan 05, 2024 9:32 pm
Tried that. Still doesn't recognize UHD. Works flawlessly with all BD.
Could it need to updated? or re-flashed?
I know people aren't fans of these LG drives but seems odd that it used to read UHD and works great with BD.
Post by d00zah » Fri Jan 05, 2024 9:49 pm
Had the blue laser gone kaput, BDs would be a no-go. For the sake of being thorough, have you retried any discs you've previously ripped successfully?
knyght1
Post by knyght1 » Fri Jan 05, 2024 10:21 pm
I just tried Avengers: Endgame 4K and it recognized it right away. So just the new ones I'm having an issue with.
onkel_joerg
Post by onkel_joerg » Fri Jan 05, 2024 10:41 pm
Which disks are not recognized?
Acer Nitro AN517-54
Win11 Home
Verbatim ASIN: B07MTP9VKX
(PIONEER BD-RW; BDR-UD04 USB Device)
Post by d00zah » Fri Jan 05, 2024 10:54 pm
Gently clean one of the problem discs... lint-free cloth, mild dish soap 1st if it's stubborn.
knyght1
Post by knyght1 » Fri Jan 05, 2024 10:57 pm
I tried that. Both discs are brand new. I even returned them both and got new discs. Same thing.
Post by d00zah » Fri Jan 05, 2024 11:03 pm
Just to be clear, it's not "The volume key is unknown for this disc - video can't be decrypted", but a "No disc inserted", correct? Lately, there can be a number reasons for a "The volume key is unknown..." msg.
knyght1
Post by knyght1 » Fri Jan 05, 2024 11:41 pm
There is no error message. The drive just spins and spins and eventually gives up and ejects. Never mounts the disc nor does MakeMKV ever provide an error message.
Post by d00zah » Sat Jan 06, 2024 12:20 am
Could be grounds for cleaning the drive optics? @Billycar11, or @MartyMcNuts might be able to offer some guidance? I've exhausted my conventional wisdom... :oops: & there's a Nor'easter brewin'.
Post by Billycar11 » Sat Jan 06, 2024 2:20 am
you can take the drive apart and clean the laser but most people dont do it
but yeah eject the try use a plastic pry tool pop off the bezel clips on the 2 sides and bottom then 4 screws on the bottom and the the top will wiggle off then you can see the lasers
dont use one of those cleaning discs they wont do anything for you
knyght1
Post by knyght1 » Sat Jan 06, 2024 2:46 am
@Billycar11 does it seem plausible that the optics need to be cleaned when it reads all BD and reads older UHD? To be clear it is not a situation where it needs to be re-flashed or updated if that even exists?
Post by MartyMcNuts » Sat Jan 06, 2024 3:17 am
knyght1 wrote: Sat Jan 06, 2024 2:46 am @Billycar11 does it seem plausible that the optics need to be cleaned when it reads all BD and reads older UHD? To be clear it is not a situation where it needs to be re-flashed or updated if that even exists?
Usually, UHD discs need to be cleaned because they are brand new.
Also, it could just be the case where that drive just doesn't like that particular disc. As silly as it sounds, it does happen occasionally. Can you test that problem disc in another drive?
Post by Billycar11 » Sat Jan 06, 2024 10:34 am
Yeah that happens all the time that new discs need to be cleaned
