Archgon MD-8107-US-UHD (LG BU40N external slim) stopped working
rinim
Post by rinim » Fri Jan 05, 2024 1:52 am
My Archgon MD-8107-US-UHD (a slim external enclosure for the LG BU40N drive) suddenly stopped working today. I bought it about 3 years ago and have been using it to rip/backup my 1080p/4K collection for the last few years without problems.
As of right now, if I plug the drive in, I hear the usual sound in Windows that a USB device was added. Also, if I open MakeMKV, it recognizes that the drive is attached, but simply says "No Disc Inserted." More troubling is that when the drive is connected, the disc does not spin up, the light on the front doesn't flash, and the eject button won't eject the disc (there's currently a disc in there). Yet, MakeMKV still recognizes that the drive is there.
I've already tried different USB ports and different USB cables (although I've only tried the ones included since I don't have any other SATA>USB cables). I normally use the SATA>USB-C cable that was included, but when this happened I also tried the SATA>USB-A cable (same problem).
When this first started happening, I had inserted a disc in the drive, but MakeMKV wasn't recognizing it (simply said "No Disc Inserted"). This has happened before, so I unplugged the drive and restarted the computer (which has fixed this issue in the past). However, this time, this new problem happened where the drive doesn't seem to respond at all...again, even though MakeMKV recognizes it's attached.
I don't know if it's relevant or not, but here's what I see in the info panel:
OS device name: F:
Product: BD-RE BU40N
Revision: 1.00
Serial number:
Firmware date: 2116-12-20 15:28
Highest AACS version: 78
Firmware version: 1.00
I'm not really sure what else to do or how else to troubleshoot. Any suggestions or thoughts?
Re: Archgon MD-8107-US-UHD (LG BU40N external slim) stopped working
Post by MartyMcNuts » Fri Jan 05, 2024 9:29 pm
OS device name: F:
Revision: 1.00
Serial number: MO9K6OD5434
It's possible that the blue laser has died or the enclosure's circuit board has issues.
To find out, try to remove the drive from the enclosure. If you can get it out, use a mini SATA connection adaptor and a powered USB to SATA adaptor and see if the drive works that way.
rinim
Post by rinim » Tue Jan 09, 2024 9:53 pm
I appreciate it! I think I've determined it's beyond me wanting to repair, so I decided to get a new one. This new one seems to be FW 1.02
This is what I see in the info panel now:
Revision: 1.02
Serial number:
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Does this one need to be flashed (or can it be)? I think what confuses me is that all these notes in the info panel say "with patched firmware," and I'm also reading that 1.04 is the encrypted FW for the slim BU40N drive. In addition, the "The all you need firmware pack" from the UHD flashing guide only has 1.03... So would I need to change to 1.03? Wouldn't that be upgrading the FW rather than downgrading?
Post by MartyMcNuts » Wed Jan 10, 2024 12:09 am
Revision: 1.02
Serial number:
Yeah, the Archgon's have Taiwan BU40N 1.02 which is encrypted. Flash it to BU40N 1.03-MK. You can leave it on 1.03-MK (if you only use MakeMKV) or then flash it to BU40N 1.00 for greater software compatibility.
rinim
Post by rinim » Wed Jan 10, 2024 1:03 am
Am I right in reading going down to 1.00 would mainly be for DVD compatibility? Otherwise, thank you!
Post by MartyMcNuts » Wed Jan 10, 2024 4:05 am
No, it's for software compatibility with UHD discs. 1.00 works with all popular rippers such as DVDFab, MakeMKV, AnyDVD etc, whereas the 1.03-MK only works with MakeMKV and AnyDVD.
