I have tried to rip Wonders of the Solar System Disc 1 there are 3 main files all just under 1 hour and about 12 - 13 gig.
I have tried to rip with Lossy and Lossless as well as both but on playback I get no Audio.
Also when I try to rework the files into smaller MKVs both Programs I use for that are unable to read them.
I have used them on all other MKVs without problems till now.
I'm using MakeMKV 1.6.12
No audio when Ripping Wonders of the Solar System Disc 1
- Contact:
Re: No audio when Ripping Wonders of the Solar System Disc 1
Please post the mediainfo output of produced MKV file. Do you get any errors in MakeMKV? What programs do you use to edit MKV files and what errors do you get?
Here id the mediainfo output.
General
Unique ID : 159489615259058671617606568166207414375 (0x77FC9524440ADC937BA43168763E6067)
Complete name : D:\BD Rip\Wonders of the Solar System Disc 1 Part 1.mkv
Format : Matroska
Format version : Version 2
File size : 12.3 GiB
Duration : 58mn 27s
Overall bit rate : 30.0 Mbps
Encoded date : UTC 2011-07-20 10:52:50
Writing application : MakeMKV v1.6.12 win(x86-release)
Writing library : libmakemkv v1.6.12 (1.2.0/1.1.0) win(x86-release)
Video
Format : VC-1
Format profile : AP@L3
Codec ID : WVC1
Codec ID/Hint : Microsoft
Duration : 58mn 27s
Bit rate : 27.9 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.538
Stream size : 11.4 GiB (93%)
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 58mn 27s
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 631 MiB (5%)
Title : 3/2+1
Language : English
Menu
00:00:00.000 : en:Chapter 00
00:09:47.360 : en:Chapter 01
00:20:42.680 : en:Chapter 02
00:34:01.120 : en:Chapter 03
00:47:23.440 : en:Chapter 04
General
Format : Matroska
Duration : 58mn 27s
Video
Format : VC-1
Codec ID : WVC1
Duration : 58mn 27s
Bit depth : 8 bits
Language : English
Audio
Format : DTS
Codec ID : A_DTS
Duration : 58mn 27s
Bit depth : 16 bits
Title : 3/2+1
Language : English
Menu
- Contact:
Please search this forum for "interlaced VC-1". Generally, you'll have big problem processing this MKV file.
