Verbatim 48000
charlie62
Verbatim 48000
Post by charlie62 »
After reading on the forums that the verbatim 48000 did not need to be flashed I bought one. This may sound stupid but my pc being relatively old I find that I do not appear to have a Ctype fitting on the rear panel of my pc. Is there another connection where I can plug into.
I’m an oldie and don’t really understand a lot of how they work so if anyone can help please thanks in advance but keep the answer short to for my
Re: Verbatim 48000
charlie62 wrote:
Thu Jan 04, 2024 10:33 pm
Dunno what this model is....
I'm assuming you are talking about the Verbatim 43888 UHD drive. If so, then you are correct. It shouldn't need flashing and should come with a USB-A to USB-C cable plus a USB-C adapter (to make it a USB-C to USB-C cable).
