LOTR 4k
telev
LOTR 4k
Post by telev »
i'm noob in 4k rip. I try to rip my first 4k BR.
I'm able to rip the disk 2 of the LOTR felloship of the ring, but the disk 1 report rapidly an error.
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '261488640'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00073.m2ts' at offset '261488640'
Failed to save title 3 to file F:/BDRip/FullDisc/SEG FPL_MainFeature_t03.mkv
Encountered 29 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Here my drive. I just flash the firmware.
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.11
Serial number: *****************
Firmware date: 2119-02-27 13:19
Bus encryption flags: 1E
Highest AACS version: 81
Firmware version: 3.11
Disc Information
Label: LOTR_FELLOWSHIP_OF_THE_RING_P1
Timestamp: 2020-10-29 19:40:43
Protection: AACS2.0/C v76
Data capacity: 75.72 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Is my disk bad ?
Thanks for you advice.
Re: LOTR 4k
Sometimes, USB drives can run out of power during a rip. These are often random failure, occurring at different places on the disk on different runs. Usually CLOSE to the same spot, but rarely IN the same spot.
Sometimes, a drive will try "too hard" to pull valid data from a disk, and time out, whether it's USB or internal powered. This can happen at the SAME PLACE, on multiple rips.
Is the drive powered by USB? If so, is it USB2, or USB3?
telev
Re: LOTR 4k
Post by telev »
It's an internal drive :wink:
Re: LOTR 4k
Internal drive would tend to indicated that the disk has a bad spot that couldn't be read past, assuming the error's in the same spot each attempt. Carefully cleaning the disk can help a lot of times.
telev
Re: LOTR 4k
Post by telev »
I already tried to clean the disk. This change the spot of the error.
I have also tried to rip the second film "The two towers", disk 1 is fine, but disk 2 report also this type of error.
I will retry later
shinynewtie
Re: LOTR 4k
Post by shinynewtie »
Any luck after trying again?
