HD-DVD Ripping AACS v3
NOP1050
Post by NOP1050 »
I'm new to this forum and have a question.
I wanted to rip my old HD DVDs with MakeMkv.
I have over 200 pieces.
I have a Toshiba SD-H802A drive for this.
I was able to rip some HD DVDs with AACS v1, but none with AACS v3 or AACS v4.
Is this due to the Toshiba drive?
Would it work with an XBOX 360 HD-DVD drive?
I hope for tips from you.
Thanks and regards
GrimFuzzyLogic
Re: HD-DVD Ripping AACS v3
Post by GrimFuzzyLogic »
I have the same problem with ripping AACS v4 discs using the XBox HD-DVD drive connected to Windows 11.
Specifically, I have the Blade Runner Collector's Edition and Transformers Special Edition HD-DVD. Both are AACS v4 and neither will get past the decrypt phase of opening the disc on makemkv v1.17.6
It looks like the common keydb.cfg that is pulled from online has keys for some HD-DVD discs but not these.
Would appreciate any guidance or pointer to help on this one.
Thanks.
