ASUS BW-16D1X-U - Flashable?
kobesolms
Post by kobesolms »
Hi everyone!
A long-time fan of MakeMKV and my first post. :)
Anyway... I am reaching out to see if I can safely flash my drive for UHD ripping. Here is my information from MakeMKV. I already have everything downloaded in terms of the flashing tool and the firmware pack... I just haven't been able to see anyone else on here with the same setup. I am also having a hard time getting the latest SDF to download.
OS device name: K:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: [redacted]
Firmware date: 2017-12-21
Highest AACS version: 68
Drive platform: RS8601
Firmware version: E111/ID76
Thanks a ton in advance!
kobesolms
Re: ASUS BW-16D1X-U - Flashable?
Post by kobesolms »
UPDATE: I manually downloaded the SDF, and that issue is resolved. (I think)
Check PM.
kobesolms
Post by kobesolms »
I tried to send you a PM but it won't let me.
Coopervid wrote: Thu Jan 04, 2024 3:26 pmCheck PM.
When I follow your instructions, it is saying "Drive and Firmware hardware types don't match."
Any suggestions?
kobesolms wrote: Thu Jan 04, 2024 4:04 pm I tried to send you a PM but it won't let me.
Any suggestions?
Email me for an auto flasher that does everything for you it does not need all that user input and your not even supposed to have that version at the request of the developer...
I'm one of the few who are authorized to distribute a different version
Any suggestions?
READ THE F...ING TUTORIAL and follow it. You need to check force flash.
You have V2. Check PM.
kobesolms
Post by kobesolms »
Coopervid wrote: Thu Jan 04, 2024 10:25 pm You have V2. Check PM.
jeroendc
Post by jeroendc »
I have a similar drive:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: [...]
Firmware date: 2020-07-21
Firmware version: ID76
Since it doesn't have the MT1959 I'm a bit weary of flashing it. I thought of flashing it to `DE_ASUS_BW-16D1HT_3.10_MK` (internal). Is that correct? Or should I do something else?
Do NOT try writing an Asus/LG firmware image to PIONEER drive!
Having pioneer hardware in that drive is unusual.
jeroendc
Post by jeroendc »
So what would you suggest I do?
luke.s99
Post by luke.s99 »
Hi, I've also bought this drive recently expecting it to be UHD compatible, I have the Pioneer RS8F00 drive platform too and can't figure out if it's safe to flash based on the posts I've already read.
luke.s99 wrote: Wed Feb 21, 2024 3:58 pm Hi, I've also bought this drive recently expecting it to be UHD compatible, I have the Pioneer RS8F00 drive platform too and can't figure out if it's safe to flash based on the posts I've already read.
That's a pioneer then email me for an automated flasher it can only be professionally flashed
lowxvi
Post by lowxvi »
Hello, I just bought the ASUS BW-16D1X-U and was under the notion that it would be able to rip UHD. I have seen posts that flashing Pioneer drives is not possible or difficult. What should I do?
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 31
lowxvi wrote: Mon Apr 22, 2024 1:51 pm Hello, I just bought the ASUS BW-16D1X-U and was under the notion that it would be able to rip UHD. I have seen posts that flashing Pioneer drives is not possible or difficult. What should I do?
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Email me for the pioneer flasher it has old fw so it can be flashed
