SixxString
Post by SixxString »
Sorry if these questions are silly. I'm new to this and I wanna make sure i understand before buying a drive just to brick it lol.
I am looking at these drives:
https://www.amazon.com/Buffalo-Portable ... B06Y45N2VL
https://www.amazon.com/BP50NB40-Portabl ... B018WQBGGU
My questions are:
In order to flash these drives, all i should need to do is run the SDFTool and use the firmware from the "All you need" pack, right? (So the file from the "LG slim BU40N" folder for the Buffalo drive and the file from "LG slim BP50NB40-NB50" for the other?) Or should i follow the video guide and still use the CMD?
The LG BP50NB40 says
BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
yet there is only one file within the "LG slim BP50NB40-NB50" folder. Should that work, or is there something im missing?
BillCosbyStillsNash
Post by BillCosbyStillsNash »
I'm getting this error and I don't know what it means:
I have not been able to find what a drive platform is. What is it and why is it holding me up?
What is "holding you up" is that you're trying to upgrade a platform that isn't upgradable. Your drive is from 2013; it would have to be from at least LATE 2015 to possibly be upgraded, and use a different processor.
SixxString wrote: Thu Jan 04, 2024 2:02 am Sorry if these questions are silly. I'm new to this and I wanna make sure i understand before buying a drive just to brick it lol.
My questions are:
SDFtool is the best tool for the job if you're on Windows.
The BP50NB40 drives need a multi-hop flashing process. First get it flashed to BP50NB40-NB50-1.03MK. Then flash it to BP60NB10 1.02MK or 1.00MK.
Chairface
Post by Chairface »
Hi. I am trying to patch a WP50NB40. I have used the SDFtool Flasher as per the instructions, and it looks like it worked (no errors), however I still can not read any 4k discs.
Patch File: HL-DT-ST-BD-RE_WP50NB40-NB50-1.03-NM00800-212005070929.bin
Firmware type: Patched (microcode access re-enabled) <<<<<
Firmware version: 1.03 <<<<<
I also tried patching using the CLI method :
.\makemkvcon64.exe f --all-yes -d E: rawflash enc -i "HL-DT-ST-BD-RE_WP50NB40-NB50-1.03-NM00800-212005070929.bin"
Again no errors. Appears to flash just fine. Still can not read any 4k discs.
Reading input file HL-DT-ST-BD-RE_WP50NB40-NB50-1.03-NM00800-212005070929.bin
Current Drive ID: HL-DT-ST_BD-RE_WP50NB40_1.03_212005070929_SIM2121673205
Using USB chipset workaround for Desktop drive handshake
100% Operation finished
Done successfully
Any other suggestions? Much obliged!
Chairface wrote: Thu Jan 04, 2024 11:00 pm Hi. I am trying to patch a WP50NB40. I have used the SDFtool Flasher as per the instructions, and it looks like it worked (no errors), however I still can not read any 4k discs.
Done successfully
The WP50NB40 drive is not UHD capable unless it has been cross-flashed. You've only done half the job. Now do the cross-flash. BU40N 1.00 is the recommended firmware.
Chairface
Post by Chairface »
Thank you, I thought I saw a previous post about DE_LG_BU40N_1.00.bin. So I snagged a copy of that too and attempted to flash with that. Again flashing with the tool seems to work, but still will not read the discs. Apologies if I missed the proper steps. Do I need to flash to DE_LG_BU40N_1.00.bin, then flash back to HL-DT-ST-BD-RE_WP50NB40-NB50-1.03-NM00800-212005070929.bin again ?
Chairface
Post by Chairface »
Actually, perhaps its the cross-flash that is not taking.
The tool reports it works:
.\makemkvcon64.exe f --all-yes -d E: rawflash -i "DE_LG_BU40N_1.00.bin"
Reading input file DE_LG_BU40N_1.00.bin
Done successfully
However MakeMKV still reports 1.03 (is this expected?)
Apologies for all the posts. I got it working using the proper recovery mode flashing in the tool. I was selecting the wrong order when picking the firmware versions.
Chairface wrote: Fri Jan 05, 2024 1:53 am
Done successfully
Read the first post of the SDFtool Flasher thread. It explains the easy cross-flashing procedure.
DWfromOK
Post by DWfromOK »
Okay, I'm new to this whole thing and I want to make sure I've got the procedure lined out correctly before I start this. I've got a WH14NS40 on firmware number 1.05 according to MakeMKV in linux. I attached a screenshot of the app to provide any additional context.
I need to side grade to the WH16NS60 1.02?
atp-flo
Post by atp-flo »
Hi guys, I just created an account to ask. I was about to order a drive from USA to Europe "Pioneer BDR-S13UBK" and to flash it myself but then I saw a post that it is not possible to flash them as 'amateur' user? So what is the current recommendation? I just want an UHD-BD drive that could do everything and is not limited by firmware. Cost don't really matter and I don't care if it is internal or external. What should I buy? I have advanced knowledge in Linux and Windows. If there is a way to flash any current sold drive without fancy professional developer hardware I'd like to know which one I should order.
Post by d00zah »
Europe? You could buy a pre-flashed/tested drive from asmcom, or one of the other vendors (by location) lurking hereabouts.
In addition to the recommendation for Asmcom, in Europe you can also buy a Verbatim 43888, which has a Pioneer UD04 inside it; it should be fully enabled right out of the box.
https://forum.makemkv.com/forum/viewtopic.php?f=16&t=30533
glc650
Post by glc650 »
dcoke22 wrote: Sun Jan 07, 2024 4:58 pm In addition to the recommendation for Asmcom, in Europe you can also buy a Verbatim 43888, which has a Pioneer UD04 inside it; it should be fully enabled right out of the box.
Is there a US version like this?
glc650 wrote: Mon Jan 08, 2024 12:59 am
No
