Re: SDFtool Flasher
Is there any reason why the SDF Flasher isn’t recognizing any of the firmware from the All You Need Firmware pack? It won’t let me select any of the files from the folder.
I’ve followed all of the other steps and I can’t seem to figure out the final step.
Re: SDFtool Flasher
Do you have MakeMKV installed? SDF Flasher is a front-end for the native CLI tool that comes w/ MakeMKV. See the list of prerequisites in post #1.sammyd1108 wrote: ↑Sun Dec 17, 2023 1:24 amIs there any reason why the SDF Flasher isn’t recognizing any of the firmware from the All You Need Firmware pack? It won’t let me select any of the files from the folder.
Re: SDFtool Flasher
Problem launching SDFTool on WIN11 PC where immediately double clicking on SDFTool app I get a WIN Defender error:
Windows protected your PC
Microsoft Defender SmartScreen prevented an unrecognized app from starting. Running this app might put your PC at risk.
App:
SDFtool Flasher.exe
Publisher:
Unknown publisher
Please advise
App:
SDFtool Flasher.exe
Publisher:
Unknown publisher
Please advise
Re: SDFtool Flasher
I have a new ' Arcggon - Ultra Slim Optical Drive - MDL MD-8107-U3 ' which firmware can I flash.
Using Makemkv can RIP CD/DVD/BR and watch a 4K UHD using PowerDVD 365, now I'd like to RIP my 4KUHD Library.
Re: SDFtool Flasher
That's because you're trying to run a program that hasn't been submitted to Microsoft for approval. At every version. It hasn't identified anything that implies "badness", other than the fact you haven't gotten this particular version approved by Microsoft (for a "small fee").Problem launching SDFTool on WIN11 PC where immediately double clicking on SDFTool app I get a WIN Defender error:
Didn't you get that when you first ran MakeMKV?
Re: SDFtool Flasher
Flashed my new LG WH16NS40 and everything looked fine - except it doesn't work. Just a silly question, but once it can do UHD disks, it can still do BluRay too, right?
Any idea what I am doing wrong?
It takes forever to read the disks. Only one time did it every completely read a disk so I could start a copy off, but that never finished.
Do I need a different/newer firmware?
I tried the "all you need" and "All you need Marty M" firmware.
I need something to try since this isn't working.
Thanks.
Thanks.
Re: SDFtool Flasher
You didn't really give us much information but hopefully you flashed it to WH16NS60 1.02-MK firmware. Also, once flashed you must power cycle the drive and try cleaning the UHD discs before trying to read them again.Millmaster wrote: ↑Fri Dec 29, 2023 12:34 pmFlashed my new LG WH16NS40 and everything looked fine - except it doesn't work. Just a silly question, but once it can do UHD disks, it can still do BluRay too, right?
Thanks.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Re: SDFtool Flasher
@MartyMcNuts,
The older model for, Slim LG-BP50NB40 with SVC CODE: NB40 Manufactured 2019, are the steps/firmware same as the newer Slim LG-BP50NB40 SVC CODE:NB52 model? If not, can you tell me the correct steps, or just the firmware I need for LG-BP50NB40 SVC CODE: NB40
Is there any differences between SVC CODE: NB40 - NB52 in these Slim LG portable Blu-ray Drives?
Re: SDFtool Flasher
I haven't come across one of those in a long while. It should have an unencrypted firmware so you could try flashing to the equivalent MK firmware version, then try directly flashing to BU40N 1.00 firmware or just follow the same process as for NB52.( ͡° ͜ʖ ͡°) wrote: ↑Sat Dec 30, 2023 4:42 pm@MartyMcNuts,
Is there any differences between SVC CODE: NB50 - NB52 in these Slim LG portable Blu-ray Drives?
The NB52 firmware has some additional checks. This is why we first flash it to BP50NB40 (NB50) 1.03-MK.
Re: SDFtool Flasher
Hi
I have the Asus BW-16D1HT
in the software it says:
Stasjon informasjon
Operativsystemets stasjons navn: E:
Produsent: ASUS
Produkt: BW-16D1HT
Revisjon: 1.01
Serienummer: K9DD7GF4943
Firmware dato: 2113-02-05 19:30
Krypteringsflagg for databus: 1F
Drive platform: MT1939
Firmware version: 1.01
BD raw metadata read: Partial
but shud it work when is says enabled?
i havent touched the flash since it says Drive platform: MT1939
Stasjon informasjon
Produsent: ASUS
Produkt: BW-16D1HT
Revisjon: 1.01
Re: SDFtool Flasher
A drive from 2013 isn't going to do much more than read regular BDs. Mine hasn't.
Re: SDFtool Flasher
Hi everyone,
I tried reflashing an LG WH16NS40 SVC Code:NS50 on a SATA to USB adapter, running as administrator via the gui tools and CLI but receive error code 0x82052603. Looking for advice on what to do with this drive or if I should seek another.
OS device name: E:
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: KLUNA9B4600
Highest AACS version: 63
Harware support: Yes
Firmware support: No
Firmware version: 1.05
Thank you for reading. Y'all do amazing work here!
-AP
c:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d E: rawflash enc -i C:\...\Downgrade-Enabled-Firmware-V.2\DE_flash_HL-DT-ST_BD-RE_WH16NS40_1.02_NS50.bin
Reading input file C:\...\Downgrade-Enabled-Firmware-V.2\DE_flash_HL-DT-ST_BD-RE_WH16NS40_1.02_NS50.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_KLUNA9B4600
98% .................................................
Write DRAM NG 05/26/03
Command produced error code 0x82052603
OS device name: E:
Revision: 1.05
-AP
Re: SDFtool Flasher
Your drive has encrypted firmware so you can't flash to WH16NS40 1.02 directly. You should flash to WH16NS60 1.02-MK (which is the recommended firmware anyway!) then to any other firmware if you choose.avagadrospotato wrote: ↑Thu Jan 04, 2024 12:17 amHi everyone,
---------------------------------------------------------------------------------Code: Select all
c:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d E: rawflash enc -i C:\...\Downgrade-Enabled-Firmware-V.2\DE_flash_HL-DT-ST_BD-RE_WH16NS40_1.02_NS50.bin Reading input file C:\...\Downgrade-Enabled-Firmware-V.2\DE_flash_HL-DT-ST_BD-RE_WH16NS40_1.02_NS50.bin Flashing flags = 0x0 : 0 0 0 0 : ---- ---- ---- ---- Sending image in encrypted format Current Drive ID: HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_KLUNA9B4600 Ready to write drive flash memory. (auto confirmed) Operation started: Sending flash image to drive 98% ................................................. Write DRAM NG 05/26/03 Command produced error code 0x82052603
OS device name: E:
Revision: 1.05
-AP
Re: SDFtool Flasher
YAY! Thank you! I was mistakenly also trying DE_LG WH16NS60_1.00.bin, which is clearly not 1.02 (doh). You're a saint for replying so quickly. Do you have a donation link?MartyMcNuts wrote: ↑Thu Jan 04, 2024 1:09 amYour drive has encrypted firmware so you can't flash to WH16NS40 1.02 directly. You should flash to WH16NS60 1.02-MK (which is the recommended firmware anyway!) then to any other firmware if you choose.avagadrospotato wrote: ↑Thu Jan 04, 2024 12:17 amHi everyone,
OS device name: E:
Revision: 1.05
-AP
OS device name: E:
Product: BD-RE WH16NS60
Revision: 1.02
Firmware version: 1.02
Re: SDFtool Flasher
Not necessary but if you want to, my PayPal is: martymcnuts@outlook.comavagadrospotato wrote: ↑Thu Jan 04, 2024 1:21 amYAY! Thank you! I was mistakenly also trying DE_LG WH16NS60_1.00.bin, which is clearly not 1.02 (doh). You're a saint for replying so quickly. Do you have a donation link?MartyMcNuts wrote: ↑Thu Jan 04, 2024 1:09 amYour drive has encrypted firmware so you can't flash to WH16NS40 1.02 directly. You should flash to WH16NS60 1.02-MK (which is the recommended firmware anyway!) then to any other firmware if you choose.avagadrospotato wrote: ↑Thu Jan 04, 2024 12:17 amHi everyone,
OS device name: E:
Revision: 1.05
-AP
OS device name: E:
Revision: 1.02
