Hi, I'm very new to sdftool. I bought a Wh14NS40 dec 23 manuf oct/23 rom v: 1.05. I've been reading everything i could about flashing but i made an stupid mistake and flashed my drive with LG BU40N 1.03. Mkv can see the drive and recognizes it as BU40N but eject button wont open, I've tried to recover it but the dump files only shows BU40N. At this moment i'm not even sure how i got here cause i tried so many different things im afraid i wont be able to fix it.
OS device name: F:
Product: BD-RE BU40N
Revision: 1.03
Serial number: KLGNAHG0717
Highest AACS version: 81
Firmware version: 1.03
Can u help pls?
Thank you
LG WH14NS40 eject wont work (wrong firmware)
Fleshnbones
Re: LG WH14NS40 eject wont work (wrong firmware)
flash to wh16NS60 1.0x may need to use the recovery option not sure but either way this is fixable
Fleshnbones
So flashed with wh16ns60. If i use write gives me error 0xff05c103. If i use recovery looks like it worked but it does not change anything.
what did you select as your wrong FW?Fleshnbones wrote: Wed Jan 03, 2024 9:15 am So flashed with wh16ns60. If i use write gives me error 0xff05c103. If i use recovery looks like it worked but it does not change anything.
Fleshnbones
Sorry I'm confused. I already used BU40N 1.03 by mistake. What you mean used as a wrong FW. I'm new to this.
The recovery option in sdf gui asks you what the wrong fw is you should be selecting bu40n 1.03Fleshnbones wrote: Wed Jan 03, 2024 7:23 pm Sorry I'm confused. I already used BU40N 1.03 by mistake. What you mean used as a wrong FW. I'm new to this.
And wh16ns60 1.0x for the regular
Fleshnbones
Thank you Billy. I was repeating the same FW 16ns60 for wrong and right. After understanding what were you saying I used BU40N as wrong and 16NS60 as right. Now it is opening and I will test copying a 4k Blu-ray.
Thank you again and happy new year.
