Batman v Superman: Dawn of Justice UHD Rip Error
drossi
Post by drossi » Tue Jan 02, 2024 6:08 pm
I have a problem when copying UHD blurays:
I don't understand where this is coming from, I'm a beginner in UHD rip.
Thank's for your help.
Pastebin error: https://pastebin.com/EYR4M9T7
My player is flashing.
Informations lecteur
Nom du lecteur SE : F:
Profil actuel : BD-ROM
Fabricant : PIONEER
Produit : BD-RW BDR-211M
Révision : 1.53
Date micrologiciel : 2020-08-03
Marqueurs d'encryptage bus : 13
Version AACS la plus haute : 61
Drive platform: RS8800
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID60
Information du disque
Titre: BATMAN_V_SUPERMAN_UE
Horodatage: 2016-06-10 21:51:23
Protection: AACS2.0/C v61
Capacité de données : 91.16 Gb
Type de disque : BD-ROM UHD
Nombre de couches : 3
Marqueurs d'encryptage bus : 80
Re: Batman v Superman: Dawn of Justice UHD Rip Error
Post by Woodstock » Tue Jan 02, 2024 7:06 pm
Erreur 'Erreur SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' survenue à la lecture de '/BDMV/STREAM/00000.m2ts' à l'offset '88623740928'
Does the error always appear at 88623740928, or does it move around between attempts?
"Always" points to an actual read error on the disk, in which case cleaning it may help.
"Moves around" often means the drive runs out of power at that point, spinning faster than it can get power for. That usually happens when the drive is powered by USB, and the particular port it's plugged into does not have sufficient power to spin it that fast.
Not knowing what your particular set-up is, it is hard to say which is which.
drossi
Post by drossi » Tue Jan 02, 2024 7:10 pm
Woodstock wrote: Tue Jan 02, 2024 7:06 pm
Thank you for your reply,
The model of my player is the Asus bw-16d1h-u pro,
it is powered by AC plug and connected to USB3.0.
I haven't checked if it's still in the same place. I'm in the process of testing it again.
I'll keep you updated
Post by Coopervid » Tue Jan 02, 2024 7:51 pm
First clean the disc with warm water and liquid soap.
drossi
Post by drossi » Tue Jan 02, 2024 9:55 pm
I cleaned my disk and everything works,
thanks for your help, and sorry for the inconvenience.
