Halloween 3 & 4 UHD
erich_7719
Halloween 3 & 4 UHD
Post by erich_7719 » Mon Jan 01, 2024 7:58 pm
I would like to start with, I enjoy MakeMKV and think it is very intuitive with how it works.
My current issue is I have the first 10 Halloween movies, they are all "collectors edition". With Halloween 3 and 4, I get the error "failed to open disk". This error happens while MakeMKV is verifying the .tbl files. When attempting to create a back up, I get the error "Backup failed." and the parsing file shows "/AACS/ContentHash002.tbl". the log shows
DEBUG: Code 0 at *>y@ce*3@Z%S'=:>:213132721
DEBUG: Code 0 at @YI7z$*p]MM^0)W:c?q:121273319
DEBUG: Code 0 at DWAOuPA.R{tp?h~qZO</:121265338
Backup failed
but no dump is being created, or I am not seeing it.
My drive information is:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KL*********
Highest AACS version: 81
Firmware version: 1.02
Individual disks
Disc Information
Label: HALLOWEEN III
Timestamp: 2021-08-13 18:51:04
Protection: AACS2.0/C v76
Data capacity: 74.25 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Disc Information
Label: HALLOWEEN 4
Timestamp: 2021-08-12 19:39:53
Data capacity: 68.83 Gb
Number of layers: 3
Could I ask for some help, either, finding or creating the dump, so I can submit it for review?
I would like to thank you in advance for any assistance you may give.
Eric
Re: Halloween 3 & 4 UHD
Post by dcoke22 » Tue Jan 02, 2024 12:31 am
I'm pretty sure the dumps end up in your MakeMKV data directory. That location is specified in MakeMKV's preferences on the General tab.
erich_7719
Post by erich_7719 » Tue Jan 02, 2024 2:22 am
Thank you for your response. I have found the dumps and have submitted them.
Thank you again.
homer420
Post by homer420 » Fri Jul 19, 2024 1:09 pm
I'm trying to back up Halloween 3 and it's telling me the device key is unknown. I have MakeMKV set to online mode, doesn't help evidently. Do I also need to do a dump and send the dump info? I'm new to this just started using this program.
Post by dcoke22 » Fri Jul 19, 2024 2:45 pm
Most likely, yes. MakeMKV should create the dump files automatically by default.
The hashed keys section of the UHD FAQ has lots of good info.
