Halloween 3 & 4 UHD
erich_7719
Halloween 3 & 4 UHD
#1 Post by erich_7719 » Mon Jan 01, 2024 7:58 pm
I would like to start with, I enjoy MakeMKV and think it is very intuitive with how it works.
My current issue is I have the first 10 Halloween movies, they are all "collectors edition". With Halloween 3 and 4, I get the error "failed to open disk". This error happens while MakeMKV is verifying the .tbl files. When attempting to create a back up, I get the error "Backup failed." and the parsing file shows "/AACS/ContentHash002.tbl". the log shows
DEBUG: Code 0 at *>y@ce*3@Z%S'=:>:213132721
DEBUG: Code 0 at @YI7z$*p]MM^0)W:c?q:121273319
DEBUG: Code 0 at DWAOuPA.R{tp?h~qZO</:121265338
Backup failed
but no dump is being created, or I am not seeing it.
My drive information is:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KL*********
Highest AACS version: 81
Firmware version: 1.02
Individual disks
Disc Information
Label: HALLOWEEN III
Timestamp: 2021-08-13 18:51:04
Protection: AACS2.0/C v76
Data capacity: 74.25 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Disc Information
Label: HALLOWEEN 4
Timestamp: 2021-08-12 19:39:53
Data capacity: 68.83 Gb
Number of layers: 3
Could I ask for some help, either, finding or creating the dump, so I can submit it for review?
I would like to thank you in advance for any assistance you may give.
Eric
Re: Halloween 3 & 4 UHD
#2 Post by dcoke22 » Tue Jan 02, 2024 12:31 am
I'm pretty sure the dumps end up in your MakeMKV data directory. That location is specified in MakeMKV's preferences on the General tab.
erich_7719
#3 Post by erich_7719 » Tue Jan 02, 2024 2:22 am
Thank you for your response. I have found the dumps and have submitted them.
Thank you again.
homer420
#4 Post by homer420 » Fri Jul 19, 2024 1:09 pm
I'm trying to back up Halloween 3 and it's telling me the device key is unknown. I have MakeMKV set to online mode, doesn't help evidently. Do I also need to do a dump and send the dump info? I'm new to this just started using this program.
#5 Post by dcoke22 » Fri Jul 19, 2024 2:45 pm
homer420 wrote: Fri Jul 19, 2024 1:09 pm I'm trying to back up Halloween 3 and it's telling me the device key is unknown. I have MakeMKV set to online mode, doesn't help evidently. Do I also need to do a dump and send the dump info? I'm new to this just started using this program.
Most likely, yes. MakeMKV should create the dump files automatically by default.
The hashed keys section of the UHD FAQ has lots of good info.
