After choosing(thanks to Billycar's recommendation in another thread) and flashing my BU40N with MK 1.03, I now need to find a enclosure to fit my tower.
My drive is wired up using SATA and SATA power since I have heard that USB can cause power issues.
I am not familiar with optical drives/enclosures.
I think I need 5.25 enclosure that will fit a slim drive AND allow for SATA/SATA power.
I have checked the Ultimate UHD Drives Flashing Guide Updated 2021 thread and the recommendations I see are:
Vantec NST-536S3-BK 5.25 case
Vantec NST-510S3-BK 9.5mm slim sata case
OWC Mercury Pro 5.25 case
The first one won't fit the slim drive and is meant for a non-slim.
The remaining two seem to be meant for external drives.
I may have messed up here. I bought the drive based on the recommendations of the performance. I didn't think about how it would fit.
I guess my questions are:
1. Can I get an enclosure that will cover this slim and fit into a 5.25 slot in the my tower?
2. Does this enclosure allow for SATA?
Thanks for any recommendations.
Which drive enclosure should I get for the BU40N?
hauntinghelix
Re: Which drive enclosure should I get for the BU40N?
I have the OWC case, and it is designed to hold your drive external to your computer and connect via USB. Internally, the drive connects via SATA to a little board in the back of the case. The pictures of it from OWC's website and/or the manual should make it more clear. https://eshop.macsales.com/item/OWC/MR3UKIT/
The adapter Billycar11 posted a link to will hold the slim optical drive in an external 5.25" bay in your computer tower. It is probably the way to go.
hauntinghelix
Thanks Billy. I will try that out.
Cor3000000323
Did that work well for you? I'm thinking of getting the same thing.
Has anyone tried the OWC slim enclosure? Looks like it's one of the few available enclosures for slimline drives these days.
https://eshop.macsales.com/item/OWC/VLSSTOPTU3/
I haven't used that enclosure, but it supports an optional external power adapter: https://eshop.macsales.com/item/OWC/MOTGPWR/salotia wrote: Sat Jul 12, 2025 2:47 pm Has anyone tried the OWC slim enclosure? Looks like it's one of the few available enclosures for slimline drives these days.
That seems like a better option and relying on bus power from a USB port.
Yup! That was the thinking, though I think I am going to try with one of the 5.25" LG drives with the OWC 5.25" enclosure instead. If I end up buying this instead, will post.dcoke22 wrote: Sat Jul 12, 2025 3:10 pmI haven't used that enclosure, but it supports an optional external power adapter: https://eshop.macsales.com/item/OWC/MOTGPWR/salotia wrote: Sat Jul 12, 2025 2:47 pm Has anyone tried the OWC slim enclosure? Looks like it's one of the few available enclosures for slimline drives these days.
