Cemetery Man (1994) Dump File Submitted
ds1972
Post by ds1972 »
UHD dump file submitted. All other discs rip fine.
Greensboropc
Re: Cemetery Man (1994) Dump File Submitted
Post by Greensboropc »
ds1972 wrote:
Wed Dec 27, 2023 8:16 pm
also submitted MKB20_v77_CEMETERY_MAN_UHD_D0AE.tgz
Greensboropc
now ripping.
andrewkach
Post by andrewkach »
I recently picked up a newer release of Cemetery Man in 4K from Severin
https://severinfilms.com/products/cemet ... se-booklet
First disc in many years of using MakeMKV that I have been unable to rip.
MakeMKV v1.17.6 win(x64-release) started
Error 'OS error - Access is denied' occurred while creating 'C:/Program Files (x86)/MakeMKV/MKB20_v77_save.tgz'
Using LibreDrive mode (v06.3 id=7FC45AF98B4B)
Error 'OS error - Access is denied' occurred while creating 'C:/Program Files (x86)/MakeMKV/MKB20_v77_CEMETERY_MAN_UHD_D0AE.tgz'
I emailed the resulting tgz file to svq@makemkv.com about a week ago and am still unable to rip.
Any suggestions or insight? I do notice that the tgz file I emailed has a different file name of "MKB20_v76_save.tgz"
Thanks for any advice.
-Andrew
The file you submitted seems to be the same as the one that was submitted in December, so it is probably a case where your system isn't able to download the later file. The fact that Windows complained about writing the TGZ file could mean that you're being blocked from writing... which would actually be normal if you're trying to save things to the MakeMKV program directory.
Where do you have MakeMKV writing to? This would be in Preferences->General, the "MakeMKV data directory". Your MakeMKV program directory SHOULD be unwritable, except during installs.
andrewkach
Hello--thanks for having a look at my problem.
My data directory is C:/Program Files (x86)/MakeMKV
The default destination for rips is a different drive altogether Y:\Works in Progress
I have used MakeMKV for years, so this is a first.
The accompanying blu-ray (non-4K) disc ripped fine, so it just seems to be the 4K disc having issues.
I tried moving the parent private_data.tar directory elsewhere and starting clean, but same result.
Moved it back, same result.
Thanks again for any suggestions.
-Andrew
andrewkach
Your comment got me thinking...
I tried running MakeMKV as administrator... even though my account IS an administrator. And it does seem to be ripping properly now.
I have ripped hundreds of discs without ever having this issue, so... no idea why this particular disc required it.
But thank you--your comment helped me in the right direction.
