tnuhnivad
Post
by tnuhnivad » Fri Dec 29, 2023 2:20 pm
Hello all,
I recently ripped a handful of xmas acquisitions for the family gathering. However, MakeMKV consistently spits out several errors before failing when trying to rip Home Alone.
Post
by Woodstock » Fri Dec 29, 2023 6:39 pm
Are the errors CONSISTENTLY at the same point, or variable around that point?
Consistently usually indicates that the disk has an error. Moving around often means the disk is shutting down after a while, often because MakeMKV tries to spin in faster than the drive can pull power for (USB configurations).
tnuhnivad
Post
by tnuhnivad » Fri Dec 29, 2023 8:26 pm
Woodstock wrote: ↑Fri Dec 29, 2023 6:39 pm
As far as I can tell, it is exactly the same spot every time. I've tried to rip it 3 times now. If true that's a shame because I literally just opened it and the disc looks pristine. Is there another way to test the disc that you know of?
I guess I'll have to try and watch the disc via VLC and see what happens.
Poinsettia
Post
by Poinsettia » Fri Nov 22, 2024 7:16 pm
I've had the same problem with my Home Alone Blu-ray.
tnuhnivad
Post
by tnuhnivad » Tue Jan 28, 2025 8:26 am
Poinsettia wrote: ↑Fri Nov 22, 2024 7:16 pm
interesting, good to know the issues is not exclusive. maybe just an issue with the data on the production disc from manufacturer
