Home Alone Error
tnuhnivad
Home Alone Error
Post by tnuhnivad »
Hello all,
I recently ripped a handful of xmas acquisitions for the family gathering. However, MakeMKV consistently spits out several errors before failing when trying to rip Home Alone.
Re: Home Alone Error
Are the errors CONSISTENTLY at the same point, or variable around that point?
Consistently usually indicates that the disk has an error. Moving around often means the disk is shutting down after a while, often because MakeMKV tries to spin in faster than the drive can pull power for (USB configurations).
tnuhnivad
Post by tnuhnivad »
Woodstock wrote: Fri Dec 29, 2023 6:39 pm Are the errors CONSISTENTLY at the same point, or variable around that point?
As far as I can tell, it is exactly the same spot every time. I've tried to rip it 3 times now. If true that's a shame because I literally just opened it and the disc looks pristine. Is there another way to test the disc that you know of? :( I guess I'll have to try and watch the disc via VLC and see what happens.
Wash the disc.
Poinsettia
Post by Poinsettia »
I've had the same problem with my Home Alone Blu-ray.
tnuhnivad
Post by tnuhnivad »
Poinsettia wrote: Fri Nov 22, 2024 7:16 pm I've had the same problem with my Home Alone Blu-ray.
interesting, good to know the issues is not exclusive. maybe just an issue with the data on the production disc from manufacturer
