LG WH16NS40 Flashing Success
trleith
#1 Post by trleith » Mon Dec 04, 2023 5:12 pm
After reading the Ultimate Flashing Guide about twelve times, I have managed to flash a LG WH16NS40 to WH16NS60. LibreDrive is enabled, direct access, unlimited speed. Everything looks great. Many thanks to everyone who made this possible. I'd bought the drive before I ever dreamed to acquire a 4K disc, or knew anything about flashing.
I seem to be getting about 4X speed ripping UHD; iostat says 17,000~18,000 rkB/s. I hoping for better, but I gather this is well within the expected range.
The Journey
I'm using MakeMKV within ARM (Automatic Ripping Machine) only, so I did the flashing operation from a command line inside the Docker container. It worked fine after copying files (SDF.bin, the firmware image for the drive) into the Docker container. One thing to note: you tell MakeMKV the path or directory where you want to save your dumped firmware. It chooses the filename; you can't override it.
Saving your old firmware looks like this
trl@svr2:~$ sudo -i
[sudo] password for trl:
root@svr2:~/LGWH16NS40# docker exec -it arm-rippers bash
# Now I'm root in the Docker container
root@svr2:~# mkdir LGWH16NS40
root@svr2:~# cd LGWH16NS40/
# In another window, download sdf.bin and the Everything You Need firmware pack. Put these things in this directory.
root@3bff7f350e08:/home/arm/LGWH16NS40# /usr/local/bin/makemkvcon f -f ./sdf.bin --drive=dev_21:2 dump
Command produced 1 file(s)
  #00: size=70Kb name=dump_user_HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_M41MALA1616.tar
Flashing looks like this
root@3bff7f350e08:/home/arm/LGWH16NS40# /usr/local/bin/makemkvcon f -f ./sdf.bin --drive=dev_21:2 rawflash enc --in=HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Reading input file HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_M41MALA1616
yes
 100% Operation finished
Done successfully
root@c87852fe1188:/home/arm/LGWH16NS40# ls -la
total 3504
drwxrwxr-x  2 root arm    4096 Dec  1 22:55 .
drwxr-xr-x 22 arm  arm    4096 Dec  4 15:41 ..
-rw-------  1 root arm   72192 Dec  1 23:15 dump_user_HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_M41MALA1616.tar
-rwxrwxr-x  1 root arm 2097152 Sep  1  2019 HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
-rwxrwxr-x  1 root arm 1408816 Dec  1 22:54 sdf.bin
Verification looks like this
ARM comes with a symbolic link that equates "sdftool" with "makemkvcon". I used that syntax here.
root@3bff7f350e08:/home/arm/LGWH16NS40# /usr/local/bin/sdftool --drive=dev_21:2 --info
SDF.bin version: 0x0097
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8105:Enabled
8001:Drive platform
:MT1959
8002:Firmware type
8107:Patched (microcode access re-enabled)
8003:Firmware version
:1.02
8005:DVD all regions
8100:Yes
8006:BD raw data read
8100:Yes
8007:BD raw metadata read
8100:Yes
8009:Unrestricted read speed
8100:Yes
[Drive Specific SDF] Embedded Status Message:
8099:Using LibreDrive mode (v%1 id=%2)
:06.3
:7FA2657C7667
Identification SDF present
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:JB8 :HL-DT-ST:BD-RE  WH16NS60 1.02:NM00100:-
I don't know why it says LibreDrive is not enabled. When you run MakeMKV later, it says it's using it. I would highlight that for you, but the BBS doesn't let you use color inside a "code" environment.
[12-04-2023 06:33:46] DEBUG ARM: makemkv.run_makemkv Ripping with the following command: makemkvcon mkv --directio=true --cache=2048 --debug -r --progress=/home/arm/logs/progress/402.log --messages=-stdout dev:/dev/sr0 all /home/arm/media/raw/The-Last-Waltz --minlength=0
MSG:1005,0,1,"MakeMKV v1.17.3 linux(x64-release) started","%1 started","MakeMKV v1.17.3 linux(x64-release)"
MSG:1004,131072,1,"Debug logging enabled, log will be saved as file:///home/arm/MakeMKV_log.txt","Debug logging enabled, log will be saved as %1","file:///home/arm/MakeMKV_log.txt"
MSG:1003,32,3,"DEBUG: Code 0 at j)b;2hEW?9IdZYnmhdZN9y:29393631","DEBUG: Code %1 at %2:%3","0","j)b;2hEW?9IdZYnmhdZN9y","29393631"
MSG:5075,131072,2,"The new version 1.17.5 is available for download at http://www.makemkv.com/download/","The new version %1 is available for download at %2","1.17.5","http://www.makemkv.com/download/"
DRV:0,0,999,0,"DVD+R-DL HL-DT-ST DVDRAM GH22LS40 LL00 DCF3AFEB8990","","/dev/sr1"
DRV:1,2,999,12,"BD-RE HL-DT-ST BD-RE  WH16NS60 1.02 M41MALA1616","THE_LAST_WALTZ","/dev/sr0"
DRV:2,256,999,0,"","",""
DRV:3,256,999,0,"","",""
DRV:4,256,999,0,"","",""
DRV:5,256,999,0,"","",""
DRV:6,256,999,0,"","",""
DRV:7,256,999,0,"","",""
DRV:8,256,999,0,"","",""
DRV:9,256,999,0,"","",""
DRV:10,256,999,0,"","",""
DRV:11,256,999,0,"","",""
DRV:12,256,999,0,"","",""
DRV:13,256,999,0,"","",""
DRV:14,256,999,0,"","",""
DRV:15,256,999,0,"","",""
MSG:1011,0,1,"Using LibreDrive mode (v06.3 id=7FA2657C7667)","%1","Using LibreDrive mode (v06.3 id=7FA2657C7667)"
MSG:3007,0,0,"Using direct disc access mode","Using direct disc access mode"
MSG:5085,0,0,"Loaded content hash table, will verify integrity of M2TS files.","Loaded content hash table, will verify integrity of M2TS files."
MSG:3307,0,2,"File 00001.mpls was added as title #0","File %1 was added as title #%2","00001.mpls","0"
MSG:3307,0,2,"File 00230.m2ts was added as title #1","File %1 was added as title #%2","00230.m2ts","1"
TheAlmightyCurd
Re: LG WH16NS40 Flashing Success
#2 Post by TheAlmightyCurd » Thu Dec 21, 2023 9:55 pm
I have the same drive and UHD worked on 1.17.4 but after the 1.17.5 update UHD discs stopped working.
MartletM
#3 Post by MartletM » Sat Dec 23, 2023 2:10 pm
I have a WH16NS40. I think mine was working with the 1.17.5.
Have two issues. My bought MakeMKV licence expired, can't seem to contact anyone to resolve.
The CDROM laser seems to have failed in mine. Was going through some old Audio CDs and it stopped recognizing them, after about 3 discs. Still recognizes Blu-Ray and UHD disc's.
#4 Post by Woodstock » Sat Dec 23, 2023 4:36 pm
The paid MakeMKV license does not expire, only the beta license does.
Make sure when you paste the license from the email into MakeMKV, though, you ONLY get the key itself - some email programs also copy in formatting information that causes problems with reading the key.
I've been doing "copy-paste" operations using Windows Notepad to "fix" this, but Microsoft is "fixing" Notepad to "fix" this "problem", so no telling how long that will work.
MartletM
#5 Post by MartletM » Sat Dec 23, 2023 4:38 pm
Thanks. The license thing seems to have resolved itself with a fresh install (of the same version).
dasunsrule32
#6 Post by dasunsrule32 » Fri Dec 29, 2023 5:37 am
This looks like you are coming from the LG fw 1.05. Is that correct? I got a new one from Amazon today and it is loaded with v1.05 as well. So should I be fine in getting it downgraded and loaded with the libre firmware?
Lumisheer
#7 Post by Lumisheer » Fri Dec 29, 2023 10:01 pm
@dasunsrule32, thinking of buying this drive myself from Amazon.
Could you please let me know if you get this working and the steps you took? I'll buy if it works. :-)
dasunsrule32
#8 Post by dasunsrule32 » Sat Dec 30, 2023 6:37 pm
Yeah, I'm going to attempt it today with the automated tool. If that doesn't work, I'll try this method.
dasunsrule32
#9 Post by dasunsrule32 » Sat Dec 30, 2023 10:46 pm
Ok, I just finished flashing using SDFtool Flasher and here is the output from MakeMKV:
OS device name: E:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KL8NAI95823
Highest AACS version: 15
Firmware version: 1.02
Looks like everything is working fine. Going to test a bluray and DVD now to make sure it's working as intended.
dasunsrule32
#10 Post by dasunsrule32 » Sun Dec 31, 2023 12:21 am
Just ripped the Jane Eyre (2011) bluray for my wife. It took about 26 minutes for the entire rip using MakeMKV. Pretty solid. Drive is surprisingly quiet as well.
Lumisheer
#11 Post by Lumisheer » Sun Dec 31, 2023 1:54 pm
Thank you for responding. I've ordered it hehe :-)
