LG wh16ns60 only shows up if a CD is used...
wsurfa
Post by wsurfa » Thu Dec 28, 2023 4:51 pm
As per the above my normally reliable LG drive now only shows in windows explorer or Makemkv when a CD is used.
Dvd/Blu-ray spin a bit but nothing happens
It shows as a dvd drive in device manager.
I guess it's died a laser death.....
So onto a Pioneer replacement?
Re: LG wh16ns60 only shows up if a CD is used...
Post by Woodstock » Thu Dec 28, 2023 5:50 pm
If you can find a Pioneer that hasn't been locked out of UHD. Some of the distributors here have such things, but if you're buying on your own, you're more likely to find UHD in a LG or Asus brand nowadays.
wsurfa
Post by wsurfa » Thu Dec 28, 2023 6:03 pm
Thanks I was probably going to go for the drives from Asmcom as they're based in the UK - any minor price difference I might get from an open market LG/Asus likely disappears in the ballache to get it to just work...:)
