The Martian - Extended Edition 4K Ultra HD main title?
scottlindner
Post by scottlindner » Mon Jul 19, 2021 8:49 pm
I couldn't find a topic for this so I'm posting. Typically I find this just Googling. I'm ripping The Martian Extended Edition 4K Ultra HD. There are two main titles 800 and 801. Based on the segment map comparison and total run time, I suspect 800 is the theatrical version and 801 is the extended edition since the extended edition adds about 10 minutes. Hopefully someone can confirm just so this is available for others to search.
Title information
Name: The Martian - Extended Edition
Source file name: 00800.mpls
Duration: 2:21:37
Chapters count: 32
Segment count: 28
Segment map: 63,64,89,65,92,116,93,66,94,67,95,68,96,69,97,70,98,71,99,72,100,76,101,77,102,78,103,79
File name: The Martian - Extended Edition_t02.mkv
Title information
Source file name: 00801.mpls
Duration: 2:31:20
Chapters count: 32
Segment count: 28
Segment map: 63,64,104,65,105,116,80,66,106,67,107,68,108,69,109,70,110,71,111,72,112,76,113,77,114,78,115,79
File name: The Martian - Extended Edition_t01.mkv
Dan-O
Re: The Martian - Extended Edition 4K Ultra HD main title?
Post by Dan-O » Mon Jul 19, 2021 9:33 pm
Yes, you're right. I have this same disc.
charnathan
Post by charnathan » Tue Jul 20, 2021 2:11 am
yeah that's correct for the US version.
This media is extremely weird since the movie is split into separate files for each chapter. When you play the movie off a full back-up, it's like it's playing a playlist file so it knows what chapters to include for the theatrical version and what is included for the extended version.
bjaurelio
Post by bjaurelio » Tue Feb 28, 2023 12:20 am
Does anyone else have an issue with playback for the extended version where the audio gets out of sync every time it goes to one of the few added bits from the extended version?
Discotech
Post by Discotech » Thu May 25, 2023 6:23 pm
YES! Came here to see if it's just me that had that issue.
bjaurelio
Post by bjaurelio » Thu Dec 28, 2023 12:30 am
I just saw a notification about your reply as I have not been here for awhile. I learned the issue is with the way the extended version injects the extended scenes. I don't know if the underlying players used by Plex, Jellyfin, etc. have been updated or not as I just went with the theatrical version once I learned this.
