Pioneer BDR-XD08EMB-S Not Ripping Disc
spaddywaddy
Post by spaddywaddy » Wed Dec 27, 2023 5:45 pm
Hi Everyone,
I haver just purchased this drive Pioneer BDR-XD08EMB-S
https://www.amazon.co.uk/dp/B0C2KPKRRR? ... ct_details
When I go to rip my Lord of the Rings Extended UHD's or any disc it saying "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive"
Could anybody help please?
Re: Pioneer BDR-XD08EMB-S Not Ripping Disc
Post by Woodstock » Wed Dec 27, 2023 6:12 pm
If the drive was manufactured after December 2022, it is likely it has been locked out of doing UHD. Lots of discussion going on about that in topics that have "pioneer" in their subjects.
spaddywaddy
Post by spaddywaddy » Wed Dec 27, 2023 7:41 pm
Thanks for your reply. May I ask if there is a way to get past this?
Post by Woodstock » Wed Dec 27, 2023 8:35 pm
At present, no. There are people working on it, but nothing heard so far.
spaddywaddy
Post by spaddywaddy » Wed Dec 27, 2023 8:48 pm
Thanks for your help. I will return the Unit and hopefully there will be a solution in the future.
Post by Coopervid » Thu Dec 28, 2023 1:18 pm
spaddywaddy wrote: Wed Dec 27, 2023 8:48 pm Thanks for your help. I will return the Unit and hopefully there will be a solution in the future.
Buy this. It will work with UHD.
https://www.amazon.co.uk/Verbatim-Exter ... 79&sr=1-38
spaddywaddy
Post by spaddywaddy » Thu Dec 28, 2023 1:41 pm
Thanks for sharing this!
spaddywaddy
Post by spaddywaddy » Thu Dec 28, 2023 3:21 pm
Coopervid wrote: Thu Dec 28, 2023 1:18 pm
I’m wondering if it would work in my M1 MacBook?
Post by Coopervid » Thu Dec 28, 2023 3:30 pm
In your M1 MacBook or with your MacBook? It will for sure work with it.
spaddywaddy
Post by spaddywaddy » Thu Dec 28, 2023 3:44 pm
Coopervid wrote: Thu Dec 28, 2023 3:30 pm In your M1 MacBook or with your MacBook? It will for sure work with it.
Yes, I meant with. Not in the business of squeezing a disc drive in a machine which was designed to not accommodate such a device. 🤣
