Possible to let one instance of MakeMKV only 'look' at one drive?
TurbogamerXD3
#1 Post by TurbogamerXD3 » Wed Dec 27, 2023 9:19 am
Hi there!
I use multiple drives and wanted to ask if there is an option to 'fixate' one instance of MakeMKV to only a single drive, so I can use each drive individually. For example an instance that would be fixated on drive 'A' wouldn't wait for drives 'B' and 'C' to recognize just to start opening drive 'A'.
Thanks in advance!
Re: Possible to let one instance of MakeMKV only 'look' at one drive?
#2 Post by Woodstock » Wed Dec 27, 2023 2:32 pm
Open Program settings, select "IO", check "Ask for single drive mode", click OK.
Restart MakeMKV.
Select which drive you wish the current instance to use. It will ignore others.
