ASUS BW 16D1X-U
zuliatiku
ASUS BW 16D1X-U
Can’t read or detect UHD disc. Can this be flash on a Mac. Thanks
Re: ASUS BW 16D1X-U
Flashing on a Mac isn't a big issue, but... what year is the drive? Asus has put different drives inside that case, some of which can be flashed to do UHD, others which cannot. Cut-off seems to be in 2018 or so.
Re: ASUS BW 16D1X-U
Copy and paste your Makemkv info in your next post.zuliatiku wrote: Sun Dec 24, 2023 11:18 am Can’t read or detect UHD disc. Can this be flash on a Mac. Thanks
hopperwelles
Re: ASUS BW 16D1X-U
Having the same issue as OP - please help!
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number: [redacted]
Firmware date: 2119-01-04 10:47
Bus encryption flags: 1F
Highest AACS version: 78
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
hopperwelles
Re: ASUS BW 16D1X-U
How am I to open an exe file on osx. I think my post above was altered before approval. I indicated I was on osx os. Thanks and HNYCoopervid wrote: Wed Dec 27, 2023 10:59 am viewtopic.php?f=16&t=19634
see how to flash. You can flash WH16NS60 1.02 directly.
Re: ASUS BW 16D1X-U
See section "How to flash video and commands"hopperwelles wrote: Tue Jan 02, 2024 10:20 pmHow am I to open an exe file on osx. I think my post above was altered before approval. I indicated I was on osx os. Thanks and HNYCoopervid wrote: Wed Dec 27, 2023 10:59 am viewtopic.php?f=16&t=19634
