WDTV Live don't play MKV's muxed since 1.6.8
rischer
Post by rischer »
WDTV don't play MKV's muxed from the following versions:
1.6.9
1.6.10
1.6.12
I think, its a known issue since 1.6.9
crowfax
Re: WDTV Live don't play MKV's muxed since 1.6.8
Post by crowfax »
I have a WD TV Live and the MKV's made with 1.6.12 are working fine. Is it all movies, or only some movies?
rischer
Post by rischer »
crowfax wrote:I have a WD TV Live and the MKV's made with 1.6.12 are working fine. Is it all movies, or only some movies?
It's all movies.
Maybe it depends on the Version of the WDTV-Device, its the newest.
crowfax
Post by crowfax »
Are you running the latest firmware?
http://www.wdc.com/wdproducts/updates/? ... fwdtv_live
rischer
Post by rischer »
crowfax wrote:Are you running the latest firmware?
Yes, of course, i have the newest Version!
So, what do you think:
I mux the same movies (Blu Rays) in the same way with 1.6.8 and 1.6.12.
The Movies with 1.6.8 are played by the WDTV, the 1.6.12 not. So, what do you think where the problem is :wink: ?
crowfax
Post by crowfax »
Give me some of the titles of discs that don't work for you. I'll test them myself.
