Need some help with a 4k disc
valutin
Post by valutin »
This is the first time we bought a 4k BD, in the past, I just update makemkv and do open, now, I had to purchase a new drive, update the firmware. I tried to open the file using VLC and makemkv, we could play the video for 1:30 then, the video froze and I had to stop. Tried to make a rip out of the BD but now makemkv is returning this:
MakeMKV v1.17.5 win(x64-release) started
Using LibreDrive mode (v06.3 id=A95C0B8B199B)
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
......... CUT because of forum limit..............
Title #00156.mpls has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00157.mpls has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00600.mpls has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00278.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01038.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01039.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00279.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01046.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00280.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01047.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00281.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00282.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00283.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00924.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00925.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00964.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00917.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00900.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00922.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00923.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00931.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00930.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00956.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00907.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00916.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00915.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00914.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00920.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00921.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00942.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00943.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00957.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00959.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00958.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00904.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00905.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00909.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00908.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00911.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00912.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00913.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00918.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00919.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00929.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00928.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00926.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00936.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00937.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00938.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00939.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00946.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00947.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00949.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00948.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00951.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00950.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00952.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00954.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00953.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00961.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00962.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Hash check failed for file 00294.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00294.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00294.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00294.m2ts at offset 780288, file is corrupt.
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 0, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 0-6144, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 6144, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 6144-12288, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 12288, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 12288-18432, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 18432, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00294.m2ts' (title #-) , future messages will be printed only to log file
Hash check failed for file 00294.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00294.m2ts.
Is this:
the issue?
What's next?
The BD is Super Mario movie.
Re: Need some help with a 4k disc
Well updating the fw was a mistake if that was a pioneer your ruined it sadly as old ones are rare and can't be downgraded
See guide below
The hash errors can only be fixed by cleaning the disc or replacing it or cleaning the drive
valutin wrote: Sat Dec 23, 2023 5:12 am Hello,
Is this:
the issue?
What's next?
Make sure you have checked the box to allow MakeMKV internet access in MakeMKV's preferences.
valutin
Post by valutin »
These are the info for drive and disk:
Product: BD-RE BU50N
Revision: 1.00
Serial number: 111HS065187
Firmware date: 2117-11-21 10:06
Highest AACS version: 77
Firmware version: 1.00
Disc Information
Label: THE_SUPER_MARIO_BROS_MOVIE
Timestamp: 2023-06-28 11:05:21
Protection: AACS2.0/C v77
Data capacity: 89.80 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
The internet access check box is checked, I just retried.
Did I flash the right firmware? BU50N from the makemkv package
valutin
Post by valutin »
Billycar11 wrote: Sat Dec 23, 2023 4:53 pm Well updating the fw was a mistake if that was a pioneer your ruined it sadly as old ones are rare and can't be downgraded
See guide below
I read the guide, I think I manage to flash everything in order, the disc is brand new. Purchased a new drive just for this disc.
But no, it was not a pioneer.
If it is a hardware issue, I'll just go buy another drive...
actually i think i know whats going on here there a bad batch of techpulse cases they may have been rebranded now as they swapped away after this issue but yeah the case does not pass through libredrive
