I updated to you 1.9.8.6 scipts and yes you are right your scripts work properly.RESET_9999 wrote: ↑Thu Dec 21, 2023 12:00 pmIn the script 3-1 it works properly, I just tested it.
If you do the xml in resolve , you have to edit L5 when you inject in 1-1 because otherwise, the dovi_tool cannot know which side is 281 or 280 but the analysis itself in resolve is correct.
Resolve still gives top 280 bottom 281 (when I input top 281 bottom 1880 in the blanking section) so i guess i just edit the L5 for resolve xml's
