Pioneer BDR-XD07TB Cross Flash
Joshwa556
Post by Joshwa556 »
Hi
I have a Pioneer BDR-XD07TB and have found it can not read UHD disks but have seen that it can be cross flashed using the BDR-XD07TUHD firmware to enable it to be able to read UHD disks and rip them using makemkv?
I have read the flashing guide post but I am failing to understand the process to flash the drive and where to get the firmware to do so as Pioneer's site only provides the latest firmware and does not have earlier versions available.
Can anyone please explain how I get the firmware I need 1.2 or 1.4?
Once I have the firmware required how I flash it to the drive?
Can my Drive be flashed from the current firmware it is on? see details below
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.02
Serial number: THDL005084WL
Firmware date: 2019-09-05
Bus encryption flags: 13
Highest AACS version: 68
Drive platform: RS8D30
Firmware version: 1.02
Thanks in advance
Josh
Re: Pioneer BDR-XD07TB Cross Flash
Pioneer drives are not publicly flashable yet the guide is for LG drives for now pioneers will be added eventually.
Email me for a pioneer flasher. See below
kkevin@gmx.net
Post by kkevin@gmx.net »
Billycar11 wrote: Sat Dec 23, 2023 4:23 am Pioneer drives are not publicly flashable yet the guide is for LG drives for now pioneers will be added eventually.
Hello Billycar11
I have the following MakeMKV output, and was curious if this drive also works with your flasher:
OS device name: E:
Revision: 1.03
Serial number: BADL013467WL
Firmware date: 2020-08-20
Firmware version: 1.03
Thank you in advance.
kkevin@gmx.net wrote: Fri Dec 29, 2023 9:44 am
Hello Billycar11
OS device name: E:
Revision: 1.03
Yes email me for the flasher
gavcolgts
Post by gavcolgts »
Hi
has there been an update to this ?
Is there a region unlocker for this drive yet ?
Thx
Gav
NVM.... have since gotten an update from Billy
