Hi!
Is there way to get this to ripping UHD Discs?
------ Status as of 24th Dec
SO i have got this far, but still no luck. I flashed it to 1.14 and updated my Make MKV to 1.17.5 the newest. Now i got showing that is LibreDrive comaptible.
It reads 2-3 min this Disc if i select the Backup (other options is not available as copying) but then ends with error. Same if i try just to open the Disc at Make MKV.
(SIdenote: My External Buffalo BRXL-16U3 shows now also as a LibreDrive compatible. But when i insert this UHD Disc in it. it reads it something like 10-20Sec. and then shows No Disc Inserted in Make MKV. So its also stuck with no luck for Ripping.)
Here are the information captures of Drives as image etc:
https://imgur.com/a/2nHgVez
https://imgur.com/a/MLUODsj
OS device name: I:
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: SGDL023094WL
Firmware date: 2020-06-15
Highest AACS version: 72
Drive platform: RS8A10
Firmware version: 1.14
Disc Information
Label: THE_RISE_OF_SKYWALKER
Timestamp: 2020-02-03 19:47:37
Protection: AACS2.0/C v72
Data capacity: 4268.66 Gb
Bus encryption flags: 80
Verbatin 43888 Slim USB-C Drive (Pioneer BDR-UD04) Problem (SOLVED)
Sammy56
Re: Verbatin 43888 Slim USB-C Drive (Pioneer BRD-UD04) Problem
Your drive should be supported even with firmware 1.11. Which version of Makemkv is installed? Is Internet access enabled?
Sammy56
I have Make Mkv version 1.16.3.. This state have stayed same all the time no change even during time versions of Make MKV changed on my system (meaning the status of the drive).Coopervid wrote: Fri Dec 22, 2023 4:47 pm Your drive should be supported even with firmware 1.11. Which version of Makemkv is installed? Is Internet access enabled?
Does other software have any affect to this not showin ok? THis also is old system where trying Win7 x64. Though that shouldnt cause issues.. To internet connection, at least all stuf works ok on system connection wise. I cannot see a reason why it wouldnt work on Make MKV..
Sammy56
I will look at that Firmware thing
just to ask also other thing.. How about this Pioneer drive BDR-209M.
Is this out of luck? its also External one USB3 connected
Branded as Buffalo BRXL-16U3 (or BRXL-16U3-EU) this have white BDXL logo down at front left, older model as the drive i guess..
Make MKV Info:
OS device name: L:
Product: BD-RW BDR-209M
Revision: 8.11
Serial number: NEDL018813WL
Firmware date: 2014-01-16
Status: Might be supported in future, keep fingers crossed
Drive platform: Pioneer RS8600
Firmware version: ID52
You need to update Makemkv to ideally the newest one. Your version is too old and doesn't support Pioneer drives.Sammy56 wrote: Sun Dec 24, 2023 1:18 amI have Make Mkv version 1.16.3.. This state have stayed same all the time no change even during time versions of Make MKV changed on my system (meaning the status of the drive).Coopervid wrote: Fri Dec 22, 2023 4:47 pm Your drive should be supported even with firmware 1.11. Which version of Makemkv is installed? Is Internet access enabled?
Does other software have any affect to this not showin ok? THis also is old system where trying Win7 x64. Though that shouldnt cause issues.. To internet connection, at least all stuf works ok on system connection wise. I cannot see a reason why it wouldnt work on Make MKV..![]()
Check also your PM.
Sammy56
I already did update to the newest after FW Flash..Coopervid wrote: Sun Dec 24, 2023 11:30 amYou need to update Makemkv to ideally the newest one. Your version is too old and doesn't support Pioneer drives.Sammy56 wrote: Sun Dec 24, 2023 1:18 amI have Make Mkv version 1.16.3.. This state have stayed same all the time no change even during time versions of Make MKV changed on my system (meaning the status of the drive).Coopervid wrote: Fri Dec 22, 2023 4:47 pm Your drive should be supported even with firmware 1.11. Which version of Makemkv is installed? Is Internet access enabled?
Check also your PM.
Sammy56
Re: Verbatin 43888 Slim USB-C Drive (Pioneer BDR-UD04) Problem Update
Greatly appreciated help! Now it works.
