I've already made a FW dump, but I thought this would be more complicated. Anyone who can confirm I'm doing the right thing here? Thanks!
Yep, that simple.KMels wrote: Thu Dec 21, 2023 11:10 pm I recently picked up a ASUS BC-12D2HT for cheap. According to makeMKV it has the original 3.11 firmware as can be seen below. At this point, is it really as simple as flashing the FW to the 3.11-MK one from MartyMcNuts' "All You Need Firmware Pack" (posted here viewtopic.php?f=16&t=22896) using the SDF flasher (as also shown below)?
<hostdev mode="subsystem" type="scsi" managed="no">
<source>
<adapter name="scsi_host4"/>
<address bus="0" target="0" unit="0"/>
</source>
<readonly/>
<address type="drive" controller="0" bus="0" target="0" unit="0"/>
</hostdev>
ERROR: Destkop drive handshake failed with error=0x820b0006, trying slim drive handshake...
ERROR: Command produced error code 0x820b0006
Perfect! Thanks a lot for quickly confirming! The flashing worked perfectly.
Yup, the FW dump output was the same for me.dannydogg wrote: Fri Dec 22, 2023 10:43 am @KMels do you have the same output?
@KMels were you successful flashing your ASUS BC-12D2HT BD drive with the 3.11 MK FW yet?
