Avatar 4K (new Best Buy steelbook)
Re: Avatar 4K (new Best Buy steelbook)
Post by SamuriHL »
FYI, MakeMKV still doesn't have support yet but there appears to be a working key in the keydb. I was able to open the disc with MakeMKV now using that.
toxxic
Post by toxxic »
Yeah I ripped it and it has a DV layer, so yeah that's the only difference as far as I can tell.
Post by SamuriHL »
Got my Avatar Collector's Edition and submitted:
MKB20_v77_Avatar_E7D0.tgz
Post by SamuriHL »
(And yes I'm turning my steelbook into a 3 disc collector's Avatar edition. Screw them :D)
darkedgex
Post by darkedgex »
SamuriHL wrote: Wed Dec 20, 2023 2:13 pmFYI, MakeMKV still doesn't have support yet but there appears to be a working key in the keydb. I was able to open the disc with MakeMKV now using that.
A working one for the collector's edition or this BBY steelbook? If for the CE, care to share?
Also, FWIW, I submitted MKB20_v77_Avatar_E7D0.tgz a few days ago (the collector's edition).
Post by SamuriHL »
I just got home but looks like a key for the CE MKB20_v77_Avatar_E7D0.tgz disc has been added to the keydb, as well. Nice. I didn't see any MakeMKV HK downloads yet so I'd say they're still unsupported in MakeMKV as of now.
DavJen
Post by DavJen »
This is probably a dumb question but can you import a key from the keydb into makemkv?
Post by SamuriHL »
I'm not sure what that even means. The keydb can be used by MakeMKV if there's a key in it for your title. But what does it mean to "import" it? Makemkv has its own internal hashed keys that aren't accessible to end users.
polskasubie
Post by polskasubie »
i have to think the user meant how do you open the disc with MakeMKV using the key from keydb?
Post by SamuriHL »
Drop the keydb.cfg file in your .MakeMKV directory. Open disc.
