mkv conversion failed: 0 titles saved, 1 failed
jedimaster
Post by jedimaster » Sat Jul 16, 2011 7:57 pm
I am getting this error on several of my DVDs using 1.6.12. Most of those I have converted so far worked but about 25% are getting above error. I've tried doing ISOs (which were done without errors) but the same error pops up. Is there a way around this? One thing I've noted: the output size stays around 4.8k while the Read Rate keeps steadily increasing which means data is being read but nothing is being saved. I'm attaching a text file containg a log of the output screen. Hope that helps!
Hmm tried streaming the DVD and all went well...
jedimaster
Re: mkv conversion failed: 0 titles saved, 1 failed
Post by jedimaster » Sun Jul 17, 2011 9:15 am
Funny. Used DVDFab on the DVDs and was able to use MakeMKV with no errors... Weird since my DVDs are already backed-up DVDs
Post by mike admin » Sun Jul 17, 2011 11:05 am
You have a broken rip ( VOB file is broken ). Please send the full log ( one written by MakeMKV and containing lines like vobs=Zxxx ) to support@makemkv.com, so workaround could be added.
setarip_old
Post by setarip_old » Sun Jul 17, 2011 6:42 pm
@jedimaster
Hi!
Do you have the same problem with MakeMKV if you use the ORIGINAL, COMMERCIAL DVDs (instead of the backup copies) DIRECTLY with MakeMKV instead?
nexttuesday
Post by nexttuesday » Sat Jul 23, 2011 2:58 am
I have this same problem periodically with commercially produced disks. Whats up?
